Is it possible to trigger content by the weather ? For instance certain content when it is cold or hot outside. Trigger videos or actually any type of content.
Would be extremely helpful.
Thanks !
Thanks !
There’s no functionality like that in Xibo at present. I’ve converted your question to a feature request so that it’s considered for future implementation.
Thank you. I know a few other systems out there offer it - but don’t
function
any where near what Xibo does.
I would imagine this being an API application which runs outside Xibo and connects to a weather source (or even a sensor
As such you could already do this with 1.8.0-alpha using the new API.
that is actually what i want to do .
Use 1.8 + … have a video / image, etc tied to Forecast and a trigger
Example …
80 + Degrees - certain video / image is displayed
60-80 degrees - certain video / image is displayed
Etc …
based on current temperate of the Device location.
You might be able to modify my example of using the sunrise and sunset times to change a background to do this currently.
Although having an actual module in Xibo would be much better.
Dan could what he is using for the images utilize a dataset for the images ?
That way the systems would cache the images and not reach our each time … Thanks
We would need this: https://github.com/xibosignage/xibo/issues/21 for the forecast module too - I have opened an enhancement request for it.
That is a feature request I made long ago
(Well at least somewhat) I will be very happy to see that.
Still hoping for this
