Weather Module stopped working
CMS Version 3.0.6
Player Type PC & WebOS
Player Version 3 rev 306
Hi, my Weather module stopped working on Sept 12. Using OpenWeather.
I believe I was using the free Open Weather 2.5. I renewed my subscription to the newer Open Weather 3. I tested my key with their web site API call and everything seems okay there.
I cleared the cache in the weather module and checked my key and settings.
But I am getting no weather when I add the widget back to my timeline. Just a blank region.
Is there a newer module that somehow needs to be installed? Any way to troubleshoot the module? Thanks
