With Dark Skk moving to Apple and shutting down there API by end of 2021 is there alternative for free API data compatible with Xibo?
Thanks you
Thanks you
I saw that news on TV…bad news indeed! that is the only good FREE weather API for xibo
We are aware of this and are currently looking for alternative providers.
Thank you
one thing I closed my eyes and turned DEAF EARS TO…WEATHER MODULE…i tried so many options before i found dark sky. and dark sky was much better. the others dont allow you to resize the weather box to best fit eventhough its free…if we should all contribute something small to support a build for xibo-own weather, i think that would be a good move. a basic weather api that allows modifications of looks and icons. else we forget about adding weather the simplest way
