I have installed the Weather module and it is updating correctly but the temperature is showing in Celsius. The display currently reads that the high today is 70 degrees C. I need to know how to change the C to an F. Thanks
This is already logged as a bug here:
You can manually override the template and change the C for an F however.
Alex,
Thanks for the info. Is the file I need to change, xibo/modules/theme/forecastio/5-day-current-day-big-circle.template?
Thanks,
Rick
You can just edit the template when you use it in the CMS. No need to edit any files
