I am new to Xibo. I have installed and setup Xibo in production mode. I want to use weather widget (forecast IO) that should be included in Xibo version 1.7.5. I don’t see the Weather or Forecast link on the left navigation when I am in edit time line. I visited forecast IO website to register for the API key. I don’t know how to enable or if I have to install the module where to download it. Any help is appreciated.
— OK I found the link on the modules page to install the widget. Problem solved.
Thanks,
