Hi, I’m running CMS and Windows client v. 1.7.1 . I’d like to configure the watchdog feature. I’ve taken a look at the documentation founder here: http://xibo.org.uk/manual/en/install_windows_client_watchdog.html. I am not finding the watchdog file that should be installed under the xibo install directory. Could someone please point me in the right direction?
Thanks.
You can download the executables for the watchdog here:
They aren’t included in the standard installation.
Also ensure you upgrade to 1.7.2 player as alot of memory related issues are resolved in that release.
Thank you. I will give it a shot.
I have downloaded:
https://github.com/xibosignage/xibo-windows-client-watchdog/archive/master.zip
In: \xibo-windows-client-watchdog-master\bin\Release
there is a XiboClientWatchdog.exe - 83,5 KB (85.504 Bytes), Montag, 12. Januar 2015, 23:03:25
When I start the exe I get the message:
is not a valid win32 application
That’s right - it is only built for x64 at the moment. We will built it for x86 once we are comfortable its working correctly (hopefully to be included in 1.7.3).
I’ve added ourselves a reminder:
