Mini PC Zotac
Linux 1.8 R6
I am not able to wake the player pc from the CMS WakeOnLan function.
When using this function from the display list, it will try (with no luck) and throws a warning saying the WoL feature is not compatible with the device.
All players and the server are on the same sub-net on a LAN.
I have tested another WakeOnLan app on the same server as the CMS and everything works fine.
thanks
