Xibo for Windows v4 R401
I have a player that is running a 35 second video. It has been playing this fine for the last few months. However, for the last couple of weeks it will, at seemingly random, have an almost inverted colour and have large screen burn like shadows of parts of the same slide on it. I’ve attached screenshots of what CMS is seeing, along with what it should look like.
If you look in particular to the left, you can see a shadow of a large thumbs up as well as the ‘sav’ from ‘save’ front and centre; however these don’t line up at all, as they are almost side by side, and with a shorter gap.
Screen activity wise, the only thing that moves in this scene is just the little arrow at the bottom, in general, all the slides just have a simple thing moving.
That said, Windows itself is fine with no display issues, and I only have to close Xibo and run it again for it to immediately start working again.
Has anyone encountered this before? I’m happy to just reinstall the player, but ideally if there’s something more obvious I’m missing I’d like to try that first!
