Hi everybody me again,
Got a bit of an issue as I’m able to make fairly decent layouts and working out how to construct them etc.
But when I preview them It is fairly limited.
My question is for the viewing through the Xibo player.
A) Is it possible to view the display from the same machine you have the server on and if so how to do it
B) What’s the best way to configure the Xibo player options in order to view the Display
Thanks again!
Erm well you can install Windows player on the same PC (assuming you are using Windows OS)
Download from - Xibo for Windows
Manual - Installation guide
As for other options, you’ll probably want to lower collection interval for that display (displays settings page, edit display profile that your device is using), this one may also interest you Enabling HTML5 in the Windows .net Player
