I have just completed the installation of v3 and there is an issue previous version was showing here permissions: Screenshot by Lightshot
The new version won`t show anything as you can see here: Screenshot by Lightshot
I need to assign each screen each user they shouldn`t seen all or nothing.
Also for the layout and campaigns are same there is no anymore showing permission option.
Is anybody able to reply with a solution?
Thank you.
Hello, the Permissions model has been replaced with Features and Share options in v3, as documented in our manual here: Features and Sharing
You will see the option labelled as Share:
Do take a look at our blog post to see whats new: What's new in Xibo version 3 - Xibo Signage
Thank you
Hi Natasha,
Oh sorry! I saw it right now.
Thank you Natasha.
system
Closed
4
