HI,
I’m trying to utilize the Philips side LEDs with a Calendar widget and yet to find any success.
Using version 4.1 on my local machine, and according to user manual, there should be an option to set an action with target set to Display and I cant find this option.
Another challenge is that in my layout I need to show current event separately from future upcoming events. I found that adding Elements or Stencils does not help as they are sharing same configuration, how can I achieve this requirement using Elements or Stencils?
Thank you.
