"upload_max_size" should be "upload_max_filesize" - 1.8 Dev
When checking requirements before installing the 1.8 Dev, if you php.ini file is not configured correctly for large uploads, the displaying note talks about changing the setting for “upload_max_size” should be “upload_max_filesize”.
