Upgrading to 2.9.10 Issues
Having an issue where the maintenance message is showing after upgrading to 2.3.10 from 2.3.9. I’ve went through the process of upgrading MySQL, but getting the same issues. This is on Windows Server with Docker.
Xibo
Creating network “xibo_default” with the default driver
Creating xibo_cms-xmr_1 … done
Creating xibo_cms-db_1 … done
Creating xibo_cms-quickchart_1 … done
Creating xibo_cms-web_1 … done
Attaching to xibo_cms-quickchart_1, xibo_cms-xmr_1, xibo_cms-db_1, xibo_cms-web_1
cms-db_1 | 2021-05-14 20:14:57+00:00 [Note] [Entrypoint]: Entrypoint script for MySQL Server 5.7.34-1debian10 started.
cms-db_1 | 2021-05-14 20:14:58+00:00 [Note] [Entrypoint]: Switching to dedicated user ‘mysql’
cms-db_1 | 2021-05-14 20:14:58+00:00 [Note] [Entrypoint]: Entrypoint script for MySQL Server 5.7.34-1debian10 started.
cms-db_1 | 2021-05-14T20:14:58.646485Z 0 [Warning] TIMESTAMP with implicit DEFAULT value is deprecated. Please use --explicit_defaults_for_timestamp server option (see documentation for more details).
cms-db_1 | 2021-05-14T20:14:58.663883Z 0 [Note] mysqld (mysqld 5.7.34) starting as process 1 …
cms-db_1 | 2021-05-14T20:14:58.686076Z 0 [Note] InnoDB: PUNCH HOLE support available
cms-db_1 | 2021-05-14T20:14:58.686086Z 0 [Note] InnoDB: Mutexes and rw_locks use GCC atomic builtins
cms-db_1 | 2021-05-14T20:14:58.686088Z 0 [Note] InnoDB: Uses event mutexes
cms-db_1 | 2021-05-14T20:14:58.686089Z 0 [Note] InnoDB: GCC builtin __atomic_thread_fence() is used for memory barrier
cms-db_1 | 2021-05-14T20:14:58.686091Z 0 [Note] InnoDB: Compressed tables use zlib 1.2.11
cms-db_1 | 2021-05-14T20:14:58.686092Z 0 [Note] InnoDB: Using Linux native AIO
cms-db_1 | 2021-05-14T20:14:58.686223Z 0 [Note] InnoDB: Number of pools: 1
cms-db_1 | 2021-05-14T20:14:58.686296Z 0 [Note] InnoDB: Using CPU crc32 instructions
cms-db_1 | 2021-05-14T20:14:58.687635Z 0 [Note] InnoDB: Initializing buffer pool, total size = 128M, instances = 1, chunk size = 128M
cms-db_1 | 2021-05-14T20:14:58.693995Z 0 [Note] InnoDB: Completed initialization of buffer pool
cms-db_1 | 2021-05-14T20:14:58.695788Z 0 [Note] InnoDB: If the mysqld execution user is authorized, page cleaner thread priority can be changed. See the man page of setpriority().
cms-db_1 | 2021-05-14T20:14:58.758568Z 0 [Note] InnoDB: Highest supported file format is Barracuda.
cms-db_1 | 2021-05-14T20:14:58.911780Z 0 [Note] InnoDB: Creating shared tablespace for temporary tables
cms-quickchart_1 | Stackdriver logging is disabled
cms-quickchart_1 | {“name”:“quickchart”,“hostname”:“87d500fe786d”,“pid”:1,“level”:30,“msg”:“Telemetry is enabled”,“time”:“2021-05-14T20:14:55.167Z”,“v”:0}
cms-quickchart_1 | Fri, 14 May 2021 20:14:55 GMT body-parser deprecated undefined extended: provide extended option at index.js:38:17
cms-db_1 | 2021-05-14T20:14:58.913298Z 0 [Note] InnoDB: Setting file ‘./ibtmp1’ size to 12 MB. Physically writing the file full; Please wait …
cms-quickchart_1 | {“name”:“quickchart”,“hostname”:“87d500fe786d”,“pid”:1,“level”:30,“msg”:“Setting request timeout: 5000 ms”,“time”:“2021-05-14T20:14:55.518Z”,“v”:0}
cms-quickchart_1 | {“name”:“quickchart”,“hostname”:“87d500fe786d”,“pid”:1,“level”:30,“msg”:“NODE_ENV: production”,“time”:“2021-05-14T20:14:55.518Z”,“v”:0}
cms-quickchart_1 | {“name”:“quickchart”,“hostname”:“87d500fe786d”,“pid”:1,“level”:30,“msg”:“Listening on port 3400”,“time”:“2021-05-14T20:14:55.518Z”,“v”:0}
cms-db_1 | 2021-05-14T20:14:59.126573Z 0 [Note] InnoDB: File ‘./ibtmp1’ size is now 12 MB.
cms-db_1 | 2021-05-14T20:14:59.134995Z 0 [Note] InnoDB: 96 redo rollback segment(s) found. 96 redo rollback segment(s) are active.
cms-db_1 | 2021-05-14T20:14:59.135011Z 0 [Note] InnoDB: 32 non-redo rollback segment(s) are active.
cms-db_1 | 2021-05-14T20:14:59.135902Z 0 [Note] InnoDB: Waiting for purge to start
cms-db_1 | 2021-05-14T20:14:59.186039Z 0 [Note] InnoDB: 5.7.34 started; log sequence number 604452396
cms-db_1 | 2021-05-14T20:14:59.186238Z 0 [Note] InnoDB: Loading buffer pool(s) from /var/lib/mysql/ib_buffer_pool
cms-db_1 | 2021-05-14T20:14:59.186254Z 0 [Note] Plugin ‘FEDERATED’ is disabled.
cms-db_1 | 2021-05-14T20:14:59.230110Z 0 [Note] Found ca.pem, server-cert.pem and server-key.pem in data directory. Trying to enable SSL support using them.
cms-db_1 | 2021-05-14T20:14:59.230123Z 0 [Note] Skipping generation of SSL certificates as certificate files are present in data directory.
cms-db_1 | 2021-05-14T20:14:59.239415Z 0 [Warning] CA certificate ca.pem is self signed.
cms-db_1 | 2021-05-14T20:14:59.239455Z 0 [Note] Skipping generation of RSA key pair as key files are present in data directory.
cms-db_1 | 2021-05-14T20:14:59.243200Z 0 [Note] Server hostname (bind-address): ‘'; port: 3306
cms-db_1 | 2021-05-14T20:14:59.243248Z 0 [Note] IPv6 is available.
cms-db_1 | 2021-05-14T20:14:59.243258Z 0 [Note] - ‘::’ resolves to ‘::’;
cms-db_1 | 2021-05-14T20:14:59.243267Z 0 [Note] Server socket created on IP: ‘::’.
cms-db_1 | 2021-05-14T20:14:59.294199Z 0 [Note] InnoDB: Buffer pool(s) load completed at 210514 20:14:59
cms-db_1 | 2021-05-14T20:15:00.083610Z 0 [Warning] Insecure configuration for --pid-file: Location ‘/var/run/mysqld’ in the path is accessible to all OS users. Consider choosing a different directory.
cms-db_1 | 2021-05-14T20:15:00.098204Z 0 [Warning] ‘proxies_priv’ entry ‘@ root@a5cb4cc0af7c’ ignored in --skip-name-resolve mode.
cms-db_1 | 2021-05-14T20:15:00.245403Z 0 [Note] Event Scheduler: Loaded 0 events
cms-web_1 | Waiting for MySQL to start - max 300 seconds
cms-db_1 | 2021-05-14T20:15:00.245524Z 0 [Note] mysqld: ready for connections.
cms-db_1 | Version: ‘5.7.34’ socket: ‘/var/run/mysqld/mysqld.sock’ port: 3306 MySQL Community Server (GPL)
cms-db_1 | 2021-05-14T20:15:09.020095Z 2 [Note] Got an error reading communication packets
cms-web_1 | MySQL started
cms-web_1 | settingId
cms-web_1 | 3
cms-web_1 | Existing Database, checking if we need to upgrade it
cms-web_1 | Phinx by CakePHP - https://phinx.org. 0.9.2
cms-web_1 |
cms-web_1 | using config file .varwwwcmsphinx.php
cms-web_1 | using config parser php
cms-web_1 | using migration paths
cms-web_1 | - /var/www/cms/db/migrations
cms-web_1 | warning no environment specified, defaulting to: production
cms-web_1 | ordering by creation time
cms-web_1 |
cms-web_1 | Status [Migration ID] Started Finished Migration Name
cms-web_1 | ----------------------------------------------------------------------------------
cms-web_1 | up 20180130073838 2021-03-26 14:23:48 2021-03-26 14:23:53 InstallMigration
cms-web_1 | up 20180131113100 2021-03-26 14:23:53 2021-03-26 14:23:53 OldUpgradeStep85Migration
cms-web_1 | up 20180131113853 2021-03-26 14:23:53 2021-03-26 14:23:53 OldUpgradeStep86Migration
cms-web_1 | up 20180131113941 2021-03-26 14:23:53 2021-03-26 14:23:53 OldUpgradeStep87Migration
cms-web_1 | up 20180131113948 2021-03-26 14:23:53 2021-03-26 14:23:53 OldUpgradeStep88Migration
cms-web_1 | up 20180131113952 2021-03-26 14:23:53 2021-03-26 14:23:53 OldUpgradeStep92Migration
cms-web_1 | up 20180131113957 2021-03-26 14:23:53 2021-03-26 14:23:53 OldUpgradeStep120Migration
cms-web_1 | up 20180131114002 2021-03-26 14:23:53 2021-03-26 14:23:53 OldUpgradeStep121Migration
cms-web_1 | up 20180131114007 2021-03-26 14:23:53 2021-03-26 14:23:53 OldUpgradeStep122Migration
cms-web_1 | up 20180131114013 2021-03-26 14:23:53 2021-03-26 14:23:53 OldUpgradeStep123Migration
cms-web_1 | up 20180131114017 2021-03-26 14:23:53 2021-03-26 14:23:53 OldUpgradeStep124Migration
cms-web_1 | up 20180131114021 2021-03-26 14:23:53 2021-03-26 14:23:53 OldUpgradeStep125Migration
cms-web_1 | up 20180131114025 2021-03-26 14:23:53 2021-03-26 14:23:53 OldUpgradeStep126Migration
cms-web_1 | up 20180131114030 2021-03-26 14:23:53 2021-03-26 14:23:53 OldUpgradeStep127Migration
cms-web_1 | up 20180131114050 2021-03-26 14:23:53 2021-03-26 14:23:53 OldUpgradeStep128Migration
cms-web_1 | up 20180131114058 2021-03-26 14:23:53 2021-03-26 14:23:53 OldUpgradeStep129Migration
cms-web_1 | up 20180131114103 2021-03-26 14:23:53 2021-03-26 14:23:53 OldUpgradeStep130Migration
cms-web_1 | up 20180131114107 2021-03-26 14:23:53 2021-03-26 14:23:53 OldUpgradeStep131Migration
cms-web_1 | up 20180131114110 2021-03-26 14:23:53 2021-03-26 14:23:53 OldUpgradeStep132Migration
cms-web_1 | up 20180131114114 2021-03-26 14:23:53 2021-03-26 14:23:53 OldUpgradeStep133Migration
cms-web_1 | up 20180131114118 2021-03-26 14:23:53 2021-03-26 14:23:53 OldUpgradeStep134Migration
cms-web_1 | up 20180131114123 2021-03-26 14:23:53 2021-03-26 14:23:53 OldUpgradeStep135Migration
cms-web_1 | up 20180131122645 2021-03-26 14:23:53 2021-03-26 14:23:54 OneRegionPerPlaylistMigration
cms-web_1 | up 20180131123038 2021-03-26 14:23:54 2021-03-26 14:23:54 PlaylistTagsMigration
cms-web_1 | up 20180131123248 2021-03-26 14:23:54 2021-03-26 14:23:54 WidgetFromToDtMigration
cms-web_1 | up 20180212143336 2021-03-26 14:23:54 2021-03-26 14:23:54 DaypartSystemEntriesAsRecords
cms-web_1 | up 20180213173846 2021-03-26 14:23:54 2021-03-26 14:23:54 MailFromNameSettingMigration
cms-web_1 | up 20180219141257 2021-03-26 14:23:54 2021-03-26 14:23:54 DisplayGroupClosureIndexToNonUnique
cms-web_1 | up 20180223180534 2021-03-26 14:23:54 2021-03-26 14:23:55 DataSetColumnFilterAndSortOptionsMigration
cms-web_1 | up 20180302182421 2021-03-26 14:23:55 2021-03-26 14:23:55 WidgetCreatedAndModifiedDtMigration
cms-web_1 | up 20180313085749 2021-03-26 14:23:55 2021-03-26 14:23:55 MediaTableEditedIdIndexMigration
cms-web_1 | up 20180320154652 2021-03-26 14:23:55 2021-03-26 14:23:55 PlaylistAddDynamicFilterMigration
cms-web_1 | up 20180327153325 2021-03-26 14:23:55 2021-03-26 14:23:56 RemoveUserLoggedInMigration
cms-web_1 | up 20180514114415 2021-03-26 14:23:56 2021-03-26 14:23:56 FixCaseOnHelpTextFieldMigration
cms-web_1 | up 20180515123835 2021-03-26 14:23:56 2021-03-26 14:23:56 LayoutPublishDraftMigration
cms-web_1 | up 20180529065816 2021-03-26 14:23:56 2021-03-26 14:23:56 DataSetTruncateFixMigration
cms-web_1 | up 20180529073531 2021-03-26 14:23:56 2021-03-26 14:23:56 DisplayAsVncLinkMigration
cms-web_1 | up 20180621134013 2021-03-26 14:23:56 2021-03-26 14:23:56 AddWidgetSyncTaskMigration
cms-web_1 | up 20180621134250 2021-03-26 14:23:56 2021-03-26 14:23:56 EventLayoutPermissionSettingMigration
cms-web_1 | up 20180906115552 2021-03-26 14:23:56 2021-03-26 14:23:56 AddForeignKeysToTagsMigration
cms-web_1 | up 20180906115606 2021-03-26 14:23:56 2021-03-26 14:23:57 AddForeignKeysToPermissionsMigration
cms-web_1 | up 20180906115712 2021-03-26 14:23:57 2021-03-26 14:23:57 AddForeignKeysToWidgetMediaMigration
cms-web_1 | up 20180906131643 2021-03-26 14:23:57 2021-03-26 14:23:57 ForgottenPasswordReminderMigration
cms-web_1 | up 20180906131716 2021-03-26 14:23:57 2021-03-26 14:23:57 DataSetRssMigration
cms-web_1 | up 20181011160130 2021-03-26 14:23:57 2021-03-26 14:24:00 SimpleSettingsMigration
cms-web_1 | up 20181113173310 2021-03-26 14:24:00 2021-03-26 14:24:00 RemoveFinanceModuleMigration
cms-web_1 | up 20181113180337 2021-03-26 14:24:00 2021-03-26 14:24:00 SplitTickerModuleMigration
cms-web_1 | up 20181126113231 2021-03-26 14:24:00 2021-03-26 14:24:00 Release1812Migration
cms-web_1 | up 20181210092443 2021-03-26 14:24:00 2021-03-26 14:24:00 RemoveImageUriModuleMigration
cms-web_1 | up 20181212114400 2021-03-26 14:24:00 2021-03-26 14:24:00 CreatePlayerVersionsTableMigration
cms-web_1 | up 20181217135044 2021-03-26 14:24:00 2021-03-26 14:24:00 EventSyncMigration
cms-web_1 | up 20190121092556 2021-03-26 14:24:00 2021-03-26 14:24:00 PlayerUpgradeAndOverrideConfigMigration
cms-web_1 | up 20190125170130 2021-03-26 14:24:00 2021-03-26 14:24:00 PlayerSoftwareVersionFieldMigration
cms-web_1 | up 20190129103831 2021-03-26 14:24:00 2021-03-26 14:24:00 AddLinuxDisplayProfileMigration
cms-web_1 | up 20190212112534 2021-03-26 14:24:00 2021-03-26 14:24:00 AddProofOfPlayStatsDurationAndCountMigration
cms-web_1 | up 20190212115432 2021-03-26 14:24:00 2021-03-26 14:24:00 AddDefaultTransitionDurationSettingMigration
cms-web_1 | up 20190213160914 2021-03-26 14:24:00 2021-03-26 14:24:00 AddGlobalStatSettingMigration
cms-web_1 | up 20190213162212 2021-03-26 14:24:00 2021-03-26 14:24:00 AddHorizontalMenuSettingMigration
cms-web_1 | up 20190214102508 2021-03-26 14:24:00 2021-03-26 14:24:00 AddLayoutEnableStat
cms-web_1 | up 20190214102516 2021-03-26 14:24:00 2021-03-26 14:24:01 AddMediaEnableStat
cms-web_1 | up 20190220165703 2021-03-26 14:24:01 2021-03-26 14:24:01 AddScheduleRecurrenceMonthlyRepeatsOnMigration
cms-web_1 | up 20190227101705 2021-03-26 14:24:01 2021-03-26 14:24:01 MakeDisplayLicenseColumnUniqueMigration
cms-web_1 | up 20190228120603 2021-03-26 14:24:01 2021-03-26 14:24:01 AddDynamicCriteriaTagsMigration
cms-web_1 | up 20190301115046 2021-03-26 14:24:01 2021-03-26 14:24:01 AdjustGenericfileValidExtensionsMigration
cms-web_1 | up 20190315134628 2021-03-26 14:24:01 2021-03-26 14:24:01 AddBandwidthLimitColumnToDisplaygroupMigration
cms-web_1 | up 20190322162052 2021-03-26 14:24:01 2021-03-26 14:24:01 AddPublishedDateColumnMigration
cms-web_1 | up 20190326163016 2021-03-26 14:24:01 2021-03-26 14:24:01 CreateLayoutHistoryTableMigration
cms-web_1 | up 20190328111718 2021-03-26 14:24:01 2021-03-26 14:24:01 AddCampaignStatMigration
cms-web_1 | up 20190401150256 2021-03-26 14:24:01 2021-03-26 14:24:01 AddScheduleNowPageMigration
cms-web_1 | up 20190509101525 2021-03-26 14:24:01 2021-03-26 14:24:01 CreateReportScheduleTableMigration
cms-web_1 | up 20190509102648 2021-03-26 14:24:01 2021-03-26 14:24:02 CreateSavedReportTableMigration
cms-web_1 | up 20190509113001 2021-03-26 14:24:02 2021-03-26 14:24:02 AddReportPageMigration
cms-web_1 | up 20190510140126 2021-03-26 14:24:02 2021-03-26 14:24:02 TwoFactorAuthMigration
cms-web_1 | up 20190514134430 2021-03-26 14:24:02 2021-03-26 14:24:04 NullableTextFieldsMigration
cms-web_1 | up 20190515094133 2021-03-26 14:24:04 2021-03-26 14:24:04 AddHtmlDatatypeMigration
cms-web_1 | up 20190515105624 2021-03-26 14:24:04 2021-03-26 14:24:04 InstallAdditionalStandardModulesMigration
cms-web_1 | up 20190517080033 2021-03-26 14:24:04 2021-03-26 14:24:04 AddForeignKeysToLktagTablesMigration
cms-web_1 | up 20190521092700 2021-03-26 14:24:04 2021-03-26 14:24:04 AddReportScheduleTaskMigration
cms-web_1 | up 20190521092930 2021-03-26 14:24:04 2021-03-26 14:24:04 AddPreviousRunDateReportScheduleMigration
cms-web_1 | up 20190521102635 2021-03-26 14:24:04 2021-03-26 14:24:04 PlaylistDurationUpdateAtTimestamp
cms-web_1 | up 20190603083836 2021-03-26 14:24:04 2021-03-26 14:24:05 ChangeStatTableStartEndColumnMigration
cms-web_1 | up 20190610150331 2021-03-26 14:24:05 2021-03-26 14:24:07 TagsWithValuesMigration
cms-web_1 | up 20190611145607 2021-03-26 14:24:07 2021-03-26 14:24:07 RemoveOldVersionTableMigration
cms-web_1 | up 20190612140955 2021-03-26 14:24:07 2021-03-26 14:24:07 DisplayTableDatabaseSchemaAdjustmentsMigration
cms-web_1 | up 20190620112611 2021-03-26 14:24:07 2021-03-26 14:24:07 MoveTidyStatsToStatsArchiveTaskMigration
cms-web_1 | up 20190620142655 2021-03-26 14:24:07 2021-03-26 14:24:08 AddPlaylistEnableStatMigration
cms-web_1 | up 20190626091331 2021-03-26 14:24:08 2021-03-26 14:24:08 WidgetHistoryMigration
cms-web_1 | up 20190626110359 2021-03-26 14:24:08 2021-03-26 14:24:08 CreateStatTableMigration
cms-web_1 | up 20190628083649 2021-03-26 14:24:08 2021-03-26 14:24:08 AddStatsMigrationTaskMigration
cms-web_1 | up 20190710213414 2021-03-26 14:24:08 2021-03-26 14:24:08 AddIsActiveReportScheduleMigration
cms-web_1 | up 20190717101342 2021-03-26 14:24:08 2021-03-26 14:24:08 NullableCommandValidationStringMigration
cms-web_1 | up 20190719074601 2021-03-26 14:24:08 2021-03-26 14:24:08 MissingDefaultValueMigration
cms-web_1 | up 20190725115532 2021-03-26 14:24:08 2021-03-26 14:24:08 AddScheduleReminderTaskMigration
cms-web_1 | up 20190801102042 2021-03-26 14:24:08 2021-03-26 14:24:08 DisplayProfileCommandLinkFixMigration
cms-web_1 | up 20190801141737 2021-03-26 14:24:08 2021-03-26 14:24:08 DatasetAddCustomHeadersColumnMigration
cms-web_1 | up 20190801142302 2021-03-26 14:24:08 2021-03-26 14:24:08 AddDoohUserTypeMigration
cms-web_1 | up 20190802145636 2021-03-26 14:24:08 2021-03-26 14:24:08 CreateScheduleReminderTableMigration
cms-web_1 | up 20190806144729 2021-03-26 14:24:08 2021-03-26 14:24:09 AddShowContentFromMigration
cms-web_1 | up 20190823081448 2021-03-26 14:24:09 2021-03-26 14:24:09 AddImageProcessingTaskMigration
cms-web_1 | up 20190828123735 2021-03-26 14:24:09 2021-03-26 14:24:09 AddDefaultSettingResizeLimitResizeThresholdMigration
cms-web_1 | up 20190903083314 2021-03-26 14:24:09 2021-03-26 14:24:09 AddGlobalSettingForCascadePermissionsMigration
cms-web_1 | up 20190905084201 2021-03-26 14:24:09 2021-03-26 14:24:09 AddSettingForDefaultTransitionTypeMigration
cms-web_1 | up 20190905084642 2021-03-26 14:24:09 2021-03-26 14:24:09 AddSettingForAutoLayoutPublishMigration
cms-web_1 | up 20190910132520 2021-03-26 14:24:09 2021-03-26 14:24:10 DisplayMoveCmsMigration
cms-web_1 | up 20190917093141 2021-03-26 14:24:10 2021-03-26 14:24:10 InterruptLayoutMigration
cms-web_1 | up 20190918090608 2021-03-26 14:24:10 2021-03-26 14:24:10 AddDefaultSettingQuickChartMigration
cms-web_1 | up 20190919154513 2021-03-26 14:24:10 2021-03-26 14:24:10 AddNotificationAttachmentFilenameNonUsersMigration
cms-web_1 | up 20190926135518 2021-03-26 14:24:10 2021-03-26 14:24:10 AddSettingForTransitionAutoApplyToLayoutMigration
cms-web_1 | up 20190926140809 2021-03-26 14:24:10 2021-03-26 14:24:10 InstallSavedReportsAndSpacerModulesMigration
cms-web_1 | up 20191001092651 2021-03-26 14:24:10 2021-03-26 14:24:10 AddNotificationOriginalFilenameMigration
cms-web_1 | up 20191022101141 2021-03-26 14:24:10 2021-03-26 14:24:10 AddCommandEntityToPermissionEntityMigration
cms-web_1 | up 20191024152519 2021-03-26 14:24:10 2021-03-26 14:24:10 AddScheduleExclusionsTableMigration
cms-web_1 | up 20191122114104 2021-03-26 14:24:10 2021-03-26 14:24:10 FixDuplicateModuleFilesMigration
cms-web_1 | up 20191126103120 2021-03-26 14:24:10 2021-03-26 14:24:10 GeoScheduleMigration
cms-web_1 | up 20191126141140 2021-03-26 14:24:10 2021-03-26 14:24:10 RemoteDataSetCsvSourceMigration
cms-web_1 | up 20191205180116 2021-03-26 14:24:10 2021-03-26 14:24:10 AddPlaylistDashboardPageUserMigration
cms-web_1 | up 20200107082625 2021-03-26 14:24:10 2021-03-26 14:24:10 DisplayAddResolutionMigration
cms-web_1 | up 20200115115935 2021-03-26 14:24:10 2021-03-26 14:24:10 AddReportScheduleMessageMigration
cms-web_1 | up 20200122143630 2021-03-26 14:24:10 2021-03-26 14:24:11 AddReleasedRequiredFileMigration
cms-web_1 | up 20200122191232 2021-03-26 14:24:11 2021-03-26 14:24:11 AddCommercialLicenceColumnMigration
cms-web_1 | up 20200129104944 2021-03-26 14:24:11 2021-03-26 14:24:11 AddEngagementsStatsMigration
cms-web_1 | up 20200130165443 2021-03-26 14:24:11 2021-03-26 14:24:11 CountdownModuleAddMigration
cms-web_1 | up 20200311110512 2021-03-31 17:52:06 2021-03-31 17:52:07 AddIsDrawerColumnMigration ** MISSING **
cms-web_1 | up 20200311110535 2021-03-31 17:52:07 2021-03-31 17:52:07 CreateActionTableMigration ** MISSING **
cms-web_1 | up 20200319093235 2021-03-31 17:52:07 2021-03-31 17:52:07 ChangeInterruptLayoutMigration ** MISSING **
cms-web_1 | up 20200401121544 2021-03-31 17:52:07 2021-03-31 17:52:07 AddSystemUserSettingMigration ** MISSING **
cms-web_1 | up 20200407143200 2021-03-31 17:52:07 2021-03-31 17:52:08 AddCodeColumnToLayoutMigration ** MISSING **
cms-web_1 | up 20200422101006 2021-03-31 17:52:08 2021-03-31 17:52:09 AddDataSetRowLimitMigration ** MISSING **
cms-web_1 | up 20200427085958 2021-03-31 17:52:09 2021-03-31 17:52:09 AddReportScheduleStartEndMigration ** MISSING **
cms-web_1 | up 20200530103029 2021-03-31 17:52:09 2021-03-31 17:52:10 DisplayRemoteLinksMigration ** MISSING **
cms-web_1 | up 20200604103141 2021-03-31 17:52:10 2021-03-31 17:52:11 CommandImprovementsMigration ** MISSING **
cms-web_1 | up 20200612141755 2021-03-31 17:52:11 2021-03-31 17:52:11 OauthUpgradeMigration ** MISSING **
cms-web_1 | up 20200720092246 2021-03-31 17:52:11 2021-03-31 17:52:11 AddSavedReportSchemaVersionMigration ** MISSING **
cms-web_1 | up 20200916134817 2021-03-31 17:52:11 2021-03-31 17:52:11 RemoveOldScreenshotsMigration ** MISSING **
cms-web_1 | up 20200917140227 2021-03-31 17:52:11 2021-03-31 17:52:11 DisplayGroupCreatedModifiedDates ** MISSING **
cms-web_1 | up 20201007080829 2021-03-31 17:52:11 2021-03-31 17:52:15 AddFoldersMigration ** MISSING **
cms-web_1 | up 20201007093511 2021-03-31 17:52:15 2021-03-31 17:52:16 FeaturesMigration ** MISSING **
cms-web_1 | up 20201025153753 2021-03-31 17:52:16 2021-03-31 17:52:16 RemoveOldPermissionSettingsMigration ** MISSING **
cms-web_1 | up 20210105105646 2021-03-31 17:52:16 2021-03-31 17:52:16 AddMcaasScopeAndRouteMigration ** MISSING **
cms-web_1 | up 20210113134628 2021-03-31 17:52:16 2021-03-31 17:52:16 EnableUserSharingFeatureOnUsersGroupMigration ** MISSING **
cms-web_1 | up 20210201150259 2021-03-31 17:52:16 2021-03-31 17:52:16 UserOnboardingMigration ** MISSING **
cms-web_1 | up 20210305131937 2021-03-31 17:52:16 2021-03-31 17:52:16 FixDuplicateTagsMigration ** MISSING **
cms-web_1 |
cms-web_1 | We will upgrade it, take a backup
cms-web_1 | mysqldump: Error: ‘Access denied; you need (at least one of) the PROCESS privilege(s) for this operation’ when trying to dump tablespaces
cms-web_1 | Running database migrations
cms-web_1 |
cms-web_1 | using adapter mysql
cms-web_1 | using database cms
cms-web_1 |
cms-web_1 | All Done. Took 0.0191s
cms-web_1 | cp: can’t stat '/var/www/cms/ca-certs/
.pem’: No such file or directory
cms-web_1 | cp: can’t stat ‘/var/www/cms/ca-certs/*.crt’: No such file or directory
cms-web_1 | WARNING: ca-certificates.crt does not contain exactly one certificate or CRL: skipping
cms-web_1 | Setting up Quickchart
cms-web_1 | Removing web/install/index.php from production container
cms-web_1 | Starting cron
cms-web_1 | AH00558: httpd: Could not reliably determine the server’s fully qualified domain name, using 172.23.0.5. Set the ‘ServerName’ directive globally to suppress this message
