Installation Method
Custom install
Operating System
Windows Server with XAMPP 7.2.34
Hello all,
Just upgraded our CMS to v2.3.14. Everything is installed and the migration was a success, but I’m having trouble understanding how it’s handling web redirects now. In v2.3.10 and earlier, I’d modify \xibo-xms\web.htaccess and add a RewriteBase line there. In v2.3.14 the .htaccess file has a note saying:
htaccess file for CMS instances running in /
if you are running using an alias or from a sub-folder, please refer to the file in docker/tmp
if you previously set a RewriteBase in here, the file in docker/tmp replaces that approach
RewriteEngine On
I’m a little confused here because we’re not using Docker. There doesn’t appear to be any Docker folder in our CMS either.
What am I missing? Thanks!
