Installation Method
Docker
Operating System
Ubuntu 20.04.6 LTS
I replaced the values in the docker-compose.yaml with the values provided with version 3.3.7 and launched the containers. But it hangs since 24 hours at the OauthUpgradeMigration stage with error message SQLSTATE[42S02]: Base table or view not found: 1051 Unknown table 'cms.oauth_session_scopes'
Please help, I’d like to go to version 4 <3
docker-compose.yaml:
version: "2.1"
services:
cms-db:
image: mysql:5.7
volumes:
- "./shared/db:/var/lib/mysql:Z"
restart: always
environment:
- MYSQL_DATABASE=cms
- MYSQL_USER=cms
- MYSQL_RANDOM_ROOT_PASSWORD=yes
mem_limit: 16g
env_file: config.env
cms-xmr:
image: ghcr.io/xibosignage/xibo-xmr:0.9
ports:
- "9508:9505"
restart: always
mem_limit: 4g
cms-web:
image: ghcr.io/xibosignage/xibo-cms:release-3.3.7
volumes:
- "./shared/cms/custom:/var/www/cms/custom:Z"
- "./shared/backup:/var/www/backup:Z"
- "./shared/cms/web/theme/custom:/var/www/cms/web/theme/custom:Z"
- "./shared/cms/library:/var/www/cms/library:Z"
- "./shared/cms/web/userscripts:/var/www/cms/web/userscripts:Z"
- "./shared/cms/ca-certs:/var/www/cms/ca-certs:Z"
restart: always
links:
- cms-db:mysql
- cms-xmr:50001
environment:
- XMR_HOST=cms-xmr
ports:
- "127.0.0.1:8088:80"
mem_limit: 16g
cms-memcached:
image: memcached:alpine
command: memcached -m 15
restart: always
mem_limit: 1G
cms-quickchart:
image: ianw/quickchart
restart: always
docker-compose logs cms-web
Attaching to directcaretest_cms-web_1
cms-web_1 | Waiting for MySQL to start - max 300 seconds
cms-web_1 | MySQL started
cms-web_1 | Configuring MySQL cnf file
cms-web_1 | Generating RSA private key, 2048 bit long modulus (2 primes)
cms-web_1 | .........+++++
cms-web_1 | .................................................................................................................+++++
cms-web_1 | e is 65537 (0x010001)
cms-web_1 | writing RSA key
cms-web_1 | settingId
cms-web_1 | 1
cms-web_1 | Existing Database, checking if we need to upgrade it
cms-web_1 | Phinx by CakePHP - https://phinx.org. 0.9.2
cms-web_1 |
cms-web_1 | using config file .varwwwcmsphinx.php
cms-web_1 | using config parser php
cms-web_1 | using migration paths
cms-web_1 | - /var/www/cms/db/migrations
cms-web_1 | warning no environment specified, defaulting to: production
cms-web_1 | ordering by creation time
cms-web_1 |
cms-web_1 | Status [Migration ID] Started Finished Migration Name
cms-web_1 | ----------------------------------------------------------------------------------
cms-web_1 | up 20180130073838 2020-03-05 13:38:02 2020-03-05 13:38:02 InstallMigration
cms-web_1 | up 20180131113100 2020-03-05 13:38:02 2020-03-05 13:38:02 OldUpgradeStep85Migration
cms-web_1 | up 20180131113853 2020-03-05 13:38:02 2020-03-05 13:38:02 OldUpgradeStep86Migration
cms-web_1 | up 20180131113941 2020-03-05 13:38:02 2020-03-05 13:38:02 OldUpgradeStep87Migration
cms-web_1 | up 20180131113948 2020-03-05 13:38:02 2020-03-05 13:38:02 OldUpgradeStep88Migration
cms-web_1 | up 20180131113952 2020-03-05 13:38:02 2020-03-05 13:38:02 OldUpgradeStep92Migration
cms-web_1 | up 20180131113957 2020-03-05 13:38:02 2020-03-05 13:38:02 OldUpgradeStep120Migration
cms-web_1 | up 20180131114002 2020-03-05 13:38:02 2020-03-05 13:38:02 OldUpgradeStep121Migration
cms-web_1 | up 20180131114007 2020-03-05 13:38:02 2020-03-05 13:38:02 OldUpgradeStep122Migration
cms-web_1 | up 20180131114013 2020-03-05 13:38:02 2020-03-05 13:38:02 OldUpgradeStep123Migration
cms-web_1 | up 20180131114017 2020-03-05 13:38:02 2020-03-05 13:38:02 OldUpgradeStep124Migration
cms-web_1 | up 20180131114021 2020-03-05 13:38:02 2020-03-05 13:38:02 OldUpgradeStep125Migration
cms-web_1 | up 20180131114025 2020-03-05 13:38:02 2020-03-05 13:38:02 OldUpgradeStep126Migration
cms-web_1 | up 20180131114030 2020-03-05 13:38:02 2020-03-05 13:38:02 OldUpgradeStep127Migration
cms-web_1 | up 20180131114050 2020-03-05 13:38:02 2020-03-05 13:38:02 OldUpgradeStep128Migration
cms-web_1 | up 20180131114058 2020-03-05 13:38:02 2020-03-05 13:38:02 OldUpgradeStep129Migration
cms-web_1 | up 20180131114103 2020-03-05 13:38:02 2020-03-05 13:38:02 OldUpgradeStep130Migration
cms-web_1 | up 20180131114107 2020-03-05 13:38:02 2020-03-05 13:38:02 OldUpgradeStep131Migration
cms-web_1 | up 20180131114110 2020-03-05 13:38:02 2020-03-05 13:38:02 OldUpgradeStep132Migration
cms-web_1 | up 20180131114114 2020-03-05 13:38:02 2020-03-05 13:38:02 OldUpgradeStep133Migration
cms-web_1 | up 20180131114118 2020-03-05 13:38:02 2020-03-05 13:38:02 OldUpgradeStep134Migration
cms-web_1 | up 20180131114123 2020-03-05 13:38:02 2020-03-05 13:38:02 OldUpgradeStep135Migration
cms-web_1 | up 20180131122645 2020-03-05 13:38:02 2020-03-05 13:38:03 OneRegionPerPlaylistMigration
cms-web_1 | up 20180131123038 2020-03-05 13:38:03 2020-03-05 13:38:03 PlaylistTagsMigration
cms-web_1 | up 20180131123248 2020-03-05 13:38:03 2020-03-05 13:38:03 WidgetFromToDtMigration
cms-web_1 | up 20180212143336 2020-03-05 13:38:03 2020-03-05 13:38:03 DaypartSystemEntriesAsRecords
cms-web_1 | up 20180213173846 2020-03-05 13:38:03 2020-03-05 13:38:03 MailFromNameSettingMigration
cms-web_1 | up 20180219141257 2020-03-05 13:38:03 2020-03-05 13:38:03 DisplayGroupClosureIndexToNonUnique
cms-web_1 | up 20180223180534 2020-03-05 13:38:03 2020-03-05 13:38:03 DataSetColumnFilterAndSortOptionsMigration
cms-web_1 | up 20180302182421 2020-03-05 13:38:03 2020-03-05 13:38:03 WidgetCreatedAndModifiedDtMigration
cms-web_1 | up 20180313085749 2020-03-05 13:38:03 2020-03-05 13:38:03 MediaTableEditedIdIndexMigration
cms-web_1 | up 20180320154652 2020-03-05 13:38:03 2020-03-05 13:38:03 PlaylistAddDynamicFilterMigration
cms-web_1 | up 20180327153325 2020-03-05 13:38:03 2020-03-05 13:38:03 RemoveUserLoggedInMigration
cms-web_1 | up 20180514114415 2020-03-05 13:38:03 2020-03-05 13:38:03 FixCaseOnHelpTextFieldMigration
cms-web_1 | up 20180515123835 2020-03-05 13:38:03 2020-03-05 13:38:04 LayoutPublishDraftMigration
cms-web_1 | up 20180529065816 2020-03-05 13:38:04 2020-03-05 13:38:04 DataSetTruncateFixMigration
cms-web_1 | up 20180529073531 2020-03-05 13:38:04 2020-03-05 13:38:04 DisplayAsVncLinkMigration
cms-web_1 | up 20180621134013 2020-03-05 13:38:04 2020-03-05 13:38:04 AddWidgetSyncTaskMigration
cms-web_1 | up 20180621134250 2020-03-05 13:38:04 2020-03-05 13:38:04 EventLayoutPermissionSettingMigration
cms-web_1 | up 20180906115552 2020-03-05 13:38:04 2020-03-05 13:38:04 AddForeignKeysToTagsMigration
cms-web_1 | up 20180906115606 2020-03-05 13:38:04 2020-03-05 13:38:04 AddForeignKeysToPermissionsMigration
cms-web_1 | up 20180906115712 2020-03-05 13:38:04 2020-03-05 13:38:04 AddForeignKeysToWidgetMediaMigration
cms-web_1 | up 20180906131643 2020-03-05 13:38:04 2020-03-05 13:38:04 ForgottenPasswordReminderMigration
cms-web_1 | up 20180906131716 2020-03-05 13:38:04 2020-03-05 13:38:04 DataSetRssMigration
cms-web_1 | up 20181011160130 2020-03-05 13:38:04 2020-03-05 13:38:05 SimpleSettingsMigration
cms-web_1 | up 20181113173310 2020-03-05 13:38:05 2020-03-05 13:38:05 RemoveFinanceModuleMigration
cms-web_1 | up 20181113180337 2020-03-05 13:38:05 2020-03-05 13:38:05 SplitTickerModuleMigration
cms-web_1 | up 20181126113231 2020-03-05 13:38:05 2020-03-05 13:38:05 Release1812Migration
cms-web_1 | up 20181210092443 2020-03-05 13:38:05 2020-03-05 13:38:05 RemoveImageUriModuleMigration
cms-web_1 | up 20181212114400 2020-03-05 13:38:05 2020-03-05 13:38:05 CreatePlayerVersionsTableMigration
cms-web_1 | up 20181217135044 2020-03-05 13:38:05 2020-03-05 13:38:05 EventSyncMigration
cms-web_1 | up 20190121092556 2020-03-05 13:38:05 2020-03-05 13:38:05 PlayerUpgradeAndOverrideConfigMigration
cms-web_1 | up 20190125170130 2020-03-05 13:38:05 2020-03-05 13:38:05 PlayerSoftwareVersionFieldMigration
cms-web_1 | up 20190129103831 2020-03-05 13:38:05 2020-03-05 13:38:05 AddLinuxDisplayProfileMigration
cms-web_1 | up 20190212112534 2020-03-05 13:43:33 2020-03-05 13:43:33 AddProofOfPlayStatsDurationAndCountMigration
cms-web_1 | up 20190212115432 2020-03-05 13:38:05 2020-03-05 13:38:05 AddDefaultTransitionDurationSettingMigration
cms-web_1 | up 20190213160914 2020-03-05 13:43:33 2020-03-05 13:43:33 AddGlobalStatSettingMigration
cms-web_1 | up 20190213162212 2020-03-05 13:38:05 2020-03-05 13:38:05 AddHorizontalMenuSettingMigration
cms-web_1 | up 20190214102508 2020-03-05 13:43:33 2020-03-05 13:43:33 AddLayoutEnableStat
cms-web_1 | up 20190214102516 2020-03-05 13:43:33 2020-03-05 13:43:33 AddMediaEnableStat
cms-web_1 | up 20190220165703 2020-03-05 13:38:05 2020-03-05 13:38:05 AddScheduleRecurrenceMonthlyRepeatsOnMigration
cms-web_1 | up 20190227101705 2020-03-05 13:38:05 2020-03-05 13:38:05 MakeDisplayLicenseColumnUniqueMigration
cms-web_1 | up 20190228120603 2020-03-05 13:38:05 2020-03-05 13:38:05 AddDynamicCriteriaTagsMigration
cms-web_1 | up 20190301115046 2020-03-05 13:38:05 2020-03-05 13:38:05 AdjustGenericfileValidExtensionsMigration
cms-web_1 | up 20190315134628 2020-03-05 13:43:33 2020-03-05 13:43:33 AddBandwidthLimitColumnToDisplaygroupMigration
cms-web_1 | up 20190322162052 2020-03-05 13:43:33 2020-03-05 13:43:33 AddPublishedDateColumnMigration
cms-web_1 | up 20190326163016 2020-03-05 13:43:33 2020-03-05 13:43:33 CreateLayoutHistoryTableMigration
cms-web_1 | up 20190328111718 2020-03-05 13:43:33 2020-03-05 13:43:33 AddCampaignStatMigration
cms-web_1 | up 20190401150256 2020-03-05 13:43:33 2020-03-05 13:43:33 AddScheduleNowPageMigration
cms-web_1 | up 20190509101525 2020-03-05 13:43:33 2020-03-05 13:43:33 CreateReportScheduleTableMigration
cms-web_1 | up 20190509102648 2020-03-05 13:43:33 2020-03-05 13:43:33 CreateSavedReportTableMigration
cms-web_1 | up 20190509113001 2020-03-05 13:43:33 2020-03-05 13:43:33 AddReportPageMigration
cms-web_1 | up 20190510140126 2020-03-05 13:43:33 2020-03-05 13:43:34 TwoFactorAuthMigration
cms-web_1 | up 20190514134430 2020-03-05 13:43:34 2020-03-05 13:43:34 NullableTextFieldsMigration
cms-web_1 | up 20190515094133 2020-03-05 13:43:34 2020-03-05 13:43:34 AddHtmlDatatypeMigration
cms-web_1 | up 20190515105624 2020-03-05 13:43:34 2020-03-05 13:43:34 InstallAdditionalStandardModulesMigration
cms-web_1 | up 20190517080033 2020-03-05 13:43:34 2020-03-05 13:43:35 AddForeignKeysToLktagTablesMigration
cms-web_1 | up 20190521092700 2020-03-05 13:43:35 2020-03-05 13:43:35 AddReportScheduleTaskMigration
cms-web_1 | up 20190521092930 2020-03-05 13:43:35 2020-03-05 13:43:35 AddPreviousRunDateReportScheduleMigration
cms-web_1 | up 20190521102635 2020-03-05 13:43:35 2020-03-05 13:43:35 PlaylistDurationUpdateAtTimestamp
cms-web_1 | up 20190603083836 2020-03-05 13:43:35 2020-03-05 13:43:35 ChangeStatTableStartEndColumnMigration
cms-web_1 | up 20190610150331 2020-03-05 13:43:35 2020-03-05 13:43:36 TagsWithValuesMigration
cms-web_1 | up 20190611145607 2020-03-05 13:43:36 2020-03-05 13:43:36 RemoveOldVersionTableMigration
cms-web_1 | up 20190612140955 2020-03-05 13:43:36 2020-03-05 13:43:36 DisplayTableDatabaseSchemaAdjustmentsMigration
cms-web_1 | up 20190620112611 2020-03-05 13:43:36 2020-03-05 13:43:36 MoveTidyStatsToStatsArchiveTaskMigration
cms-web_1 | up 20190620142655 2020-03-05 13:43:36 2020-03-05 13:43:37 AddPlaylistEnableStatMigration
cms-web_1 | up 20190626091331 2020-03-05 13:43:37 2020-03-05 13:43:37 WidgetHistoryMigration
cms-web_1 | up 20190626110359 2020-03-05 13:43:37 2020-03-05 13:43:37 CreateStatTableMigration
cms-web_1 | up 20190628083649 2020-03-05 13:43:37 2020-03-05 13:43:37 AddStatsMigrationTaskMigration
cms-web_1 | up 20190710213414 2020-03-05 13:43:37 2020-03-05 13:43:37 AddIsActiveReportScheduleMigration
cms-web_1 | up 20190717101342 2020-03-05 13:43:37 2020-03-05 13:43:37 NullableCommandValidationStringMigration
cms-web_1 | up 20190719074601 2020-03-05 13:43:37 2020-03-05 13:43:37 MissingDefaultValueMigration
cms-web_1 | up 20190725115532 2020-03-05 13:47:56 2020-03-05 13:47:56 AddScheduleReminderTaskMigration
cms-web_1 | up 20190801102042 2020-03-05 13:43:37 2020-03-05 13:43:37 DisplayProfileCommandLinkFixMigration
cms-web_1 | up 20190801141737 2020-03-05 13:47:56 2020-03-05 13:47:56 DatasetAddCustomHeadersColumnMigration
cms-web_1 | up 20190801142302 2020-03-05 13:47:56 2020-03-05 13:47:56 AddDoohUserTypeMigration
cms-web_1 | up 20190802145636 2020-03-05 13:47:56 2020-03-05 13:47:56 CreateScheduleReminderTableMigration
cms-web_1 | up 20190806144729 2020-03-05 13:47:56 2020-03-05 13:47:56 AddShowContentFromMigration
cms-web_1 | up 20190823081448 2020-03-05 13:47:56 2020-03-05 13:47:56 AddImageProcessingTaskMigration
cms-web_1 | up 20190828123735 2020-03-05 13:47:56 2020-03-05 13:47:56 AddDefaultSettingResizeLimitResizeThresholdMigration
cms-web_1 | up 20190903083314 2020-03-05 13:47:56 2020-03-05 13:47:56 AddGlobalSettingForCascadePermissionsMigration
cms-web_1 | up 20190905084201 2020-03-05 13:47:56 2020-03-05 13:47:56 AddSettingForDefaultTransitionTypeMigration
cms-web_1 | up 20190905084642 2020-03-05 13:47:56 2020-03-05 13:47:56 AddSettingForAutoLayoutPublishMigration
cms-web_1 | up 20190910132520 2020-03-05 13:47:56 2020-03-05 13:47:56 DisplayMoveCmsMigration
cms-web_1 | up 20190917093141 2020-03-05 13:47:56 2020-03-05 13:47:56 InterruptLayoutMigration
cms-web_1 | up 20190918090608 2020-03-05 13:47:56 2020-03-05 13:47:56 AddDefaultSettingQuickChartMigration
cms-web_1 | up 20190919154513 2020-03-05 13:47:56 2020-03-05 13:47:56 AddNotificationAttachmentFilenameNonUsersMigration
cms-web_1 | up 20190926135518 2020-03-05 13:47:56 2020-03-05 13:47:56 AddSettingForTransitionAutoApplyToLayoutMigration
cms-web_1 | up 20190926140809 2020-03-05 13:47:56 2020-03-05 13:47:56 InstallSavedReportsAndSpacerModulesMigration
cms-web_1 | up 20191001092651 2020-03-05 13:47:56 2020-03-05 13:47:57 AddNotificationOriginalFilenameMigration
cms-web_1 | up 20191022101141 2020-03-05 13:52:57 2020-03-05 13:52:57 AddCommandEntityToPermissionEntityMigration
cms-web_1 | up 20191024152519 2020-03-05 13:52:57 2020-03-05 13:52:57 AddScheduleExclusionsTableMigration
cms-web_1 | up 20191122114104 2020-03-05 13:47:57 2020-03-05 13:47:57 FixDuplicateModuleFilesMigration
cms-web_1 | up 20191126103120 2020-03-05 13:52:57 2020-03-05 13:52:57 GeoScheduleMigration
cms-web_1 | up 20191126141140 2020-03-05 13:52:57 2020-03-05 13:52:58 RemoteDataSetCsvSourceMigration
cms-web_1 | up 20191205180116 2020-03-05 13:52:58 2020-03-05 13:52:58 AddPlaylistDashboardPageUserMigration
cms-web_1 | up 20200107082625 2020-03-05 13:52:58 2020-03-05 13:52:58 DisplayAddResolutionMigration
cms-web_1 | up 20200115115935 2020-03-05 13:52:58 2020-03-05 13:52:58 AddReportScheduleMessageMigration
cms-web_1 | up 20200122143630 2020-03-05 13:52:58 2020-03-05 13:52:58 AddReleasedRequiredFileMigration
cms-web_1 | up 20200122191232 2020-03-05 13:52:58 2020-03-05 13:52:58 AddCommercialLicenceColumnMigration
cms-web_1 | up 20200129104944 2020-03-05 13:52:58 2020-03-05 13:52:59 AddEngagementsStatsMigration
cms-web_1 | up 20200130165443 2020-03-05 13:52:59 2020-03-05 13:52:59 CountdownModuleAddMigration
cms-web_1 | down 20200311110512 AddIsDrawerColumnMigration
cms-web_1 | down 20200311110535 CreateActionTableMigration
cms-web_1 | down 20200319093235 ChangeInterruptLayoutMigration
cms-web_1 | down 20200401121544 AddSystemUserSettingMigration
cms-web_1 | down 20200407143200 AddCodeColumnToLayoutMigration
cms-web_1 | down 20200422101006 AddDataSetRowLimitMigration
cms-web_1 | down 20200427085958 AddReportScheduleStartEndMigration
cms-web_1 | down 20200530103029 DisplayRemoteLinksMigration
cms-web_1 | down 20200604103141 CommandImprovementsMigration
cms-web_1 | down 20200612141755 OauthUpgradeMigration
cms-web_1 | down 20200720092246 AddSavedReportSchemaVersionMigration
cms-web_1 | down 20200916134817 RemoveOldScreenshotsMigration
cms-web_1 | down 20200917140227 DisplayGroupCreatedModifiedDates
cms-web_1 | down 20201007080829 AddFoldersMigration
cms-web_1 | down 20201007093511 FeaturesMigration
cms-web_1 | down 20201025153753 RemoveOldPermissionSettingsMigration
cms-web_1 | down 20210105105646 AddMcaasScopeAndRouteMigration
cms-web_1 | down 20210113134628 EnableUserSharingFeatureOnUsersGroupMigration
cms-web_1 | down 20210128143602 MenuBoardsMigration
cms-web_1 | down 20210201150259 UserOnboardingMigration
cms-web_1 | down 20210305131937 FixDuplicateTagsMigration
cms-web_1 | down 20210407111756 RemoveReportNameColumnFromSavedReportMigration
cms-web_1 | down 20210421142731 RemoveMaintenanceKeyMigration
cms-web_1 | down 20210601104441 AddUserAgentToDataSetMigration
cms-web_1 | down 20210603114231 NewCalendarTypeMigration
cms-web_1 | down 20210608142925 AddOrientationToResolutionAndMediaMigration
cms-web_1 | down 20210611122809 AddPurgeListTableMigration
cms-web_1 | down 20210806122814 AddNumberOfItemsToPlaylistMigration
cms-web_1 | down 20210813094723 AddCycleBasedPlaybackOptionToCampaignMigration
cms-web_1 | down 20210817105702 AddCustomSeparatorToDatasetMigration
cms-web_1 | down 20210820100520 AddActionEventTypeMigration
cms-web_1 | down 20210901134913 AddIpAddressColumnToAuditLogMigration
cms-web_1 | down 20210901150615 AddTooltipAndIsRequiredColumnsMigration
cms-web_1 | down 20211109130951 FixOrphanedDisplayGroupsMigration
cms-web_1 | down 20211109134929 FixPlaylistManagerUserGroupMigration
cms-web_1 | down 20211109141925 DatasetAddOptionToTruncateOnNoNewDataMigration
cms-web_1 | down 20211116153103 ConnectorsMigration
cms-web_1 | down 20211231141457 AddMoreTagFilteringOptionsMigration
cms-web_1 | down 20211231153355 AddIsCustomToDisplayProfileMigration
cms-web_1 | down 20220117150212 AddLayoutExchangeConnectorMigration
cms-web_1 | down 20220119124436 AddCodeColumnToMenuBoardsMigration
cms-web_1 | down 20220131151346 AddDateFormatToDataSetColumnMigration
cms-web_1 | down 20220201163832 ReportLogoMigration
cms-web_1 | down 20220203145712 ApplicationsTweaksMigration
cms-web_1 | down 20220207160047 TidyCalendarModuleTypes
cms-web_1 | down 20220224130122 AddResolutionRoutesToDesignScopeMigration
cms-web_1 | down 20220225105237 MergeWeatherWidgets
cms-web_1 | down 20220302152503 LayoutRemoveOrientationMigration
cms-web_1 | down 20220307134554 AddWorldClockMigration
cms-web_1 | down 20220906085300 ThreeTwoZeroMigration
cms-web_1 | down 20220907135653 AddLogicalOperatorNameMigration
cms-web_1 | down 20220907143500 UserHomeFolderMigration
cms-web_1 | down 20221013103000 AdvertisingConnectorsMigration
cms-web_1 | down 20221024082400 AdCampaignMigration
cms-web_1 | down 20221101090337 CreateDisplayTypeTableMigration
cms-web_1 | down 20221101130018 AddDisplayMetaDataMigration
cms-web_1 | down 20221104095722 CreateDisplayLocationTypeTableMigration
cms-web_1 |
cms-web_1 | We will upgrade it, take a backup
cms-web_1 | mysqldump: Error: 'Access denied; you need (at least one of) the PROCESS privilege(s) for this operation' when trying to dump tablespaces
cms-web_1 | Running database migrations
cms-web_1 |
cms-web_1 | using adapter mysql
cms-web_1 | using database cms
cms-web_1 |
cms-web_1 | == 20200311110512 AddIsDrawerColumnMigration: migrating
cms-web_1 | == 20200311110512 AddIsDrawerColumnMigration: migrated 0.2013s
cms-web_1 |
cms-web_1 | == 20200311110535 CreateActionTableMigration: migrating
cms-web_1 | == 20200311110535 CreateActionTableMigration: migrated 0.0596s
cms-web_1 |
cms-web_1 | == 20200319093235 ChangeInterruptLayoutMigration: migrating
cms-web_1 | == 20200319093235 ChangeInterruptLayoutMigration: migrated 0.4652s
cms-web_1 |
cms-web_1 | == 20200401121544 AddSystemUserSettingMigration: migrating
cms-web_1 | == 20200401121544 AddSystemUserSettingMigration: migrated 0.1712s
cms-web_1 |
cms-web_1 | == 20200407143200 AddCodeColumnToLayoutMigration: migrating
cms-web_1 | == 20200407143200 AddCodeColumnToLayoutMigration: migrated 0.4215s
cms-web_1 |
cms-web_1 | == 20200422101006 AddDataSetRowLimitMigration: migrating
cms-web_1 | == 20200422101006 AddDataSetRowLimitMigration: migrated 0.2130s
cms-web_1 |
cms-web_1 | == 20200427085958 AddReportScheduleStartEndMigration: migrating
cms-web_1 | == 20200427085958 AddReportScheduleStartEndMigration: migrated 0.3091s
cms-web_1 |
cms-web_1 | == 20200530103029 DisplayRemoteLinksMigration: migrating
cms-web_1 | == 20200530103029 DisplayRemoteLinksMigration: migrated 0.6403s
cms-web_1 |
cms-web_1 | == 20200604103141 CommandImprovementsMigration: migrating
cms-web_1 | == 20200604103141 CommandImprovementsMigration: migrated 0.3924s
cms-web_1 |
cms-web_1 | == 20200612141755 OauthUpgradeMigration: migrating
cms-web_1 |
cms-web_1 | In PdoAdapter.php line 134:
cms-web_1 |
cms-web_1 | SQLSTATE[42S02]: Base table or view not found: 1051 Unknown table 'cms.oaut
cms-web_1 | h_session_scopes'
cms-web_1 |
cms-web_1 |
cms-web_1 | migrate [-c|--configuration CONFIGURATION] [-p|--parser PARSER] [-e|--environment ENVIRONMENT] [-t|--target TARGET] [-d|--date DATE] [-x|--dry-run]
cms-web_1 |
cms-web_1 | cp: can't stat '/var/www/cms/ca-certs/*.pem': No such file or directory
cms-web_1 | cp: can't stat '/var/www/cms/ca-certs/*.crt': No such file or directory
cms-web_1 | Setting up Quickchart
cms-web_1 | Removing web/install/index.php from production container
cms-web_1 | Starting cron
cms-web_1 | AH00558: httpd: Could not reliably determine the server's fully qualified domain name, using 172.20.0.6. Set the 'ServerName' directive globally to suppress this message
