Hi
I have got an Android device which has the version 1.8 and version code 102.
After updating to Xibo_for_Android_v1.8_R109.apk from CMS, after rebooting, a window appears
. Nothing works until you close it.
How to fix it?
Hi there and welcome!
As mentioned in the release announcement, that upgrade will require you to set your launcher according to your preferences. In response to popular demand we made Xibo “home screen” ready and unfortunately that does mean you need to make a choice which one to use if you have multiple launchers.
Once set the device should remember that decision.
