Unable to load DLL 'libcef'. (Solved)
Windows XP SP3, cant run client 1.7.1, error Unable to load DLL ‘libcef’: Exception from HRESULT: 0xC000001D
Edit: same with 1.7.2
CEF should be off by default - can you make sure you haven’t enabled it in the display settings profile in the CMS?
This is new installation, I cant even set CMS address in xibo player, getting this error when trying to launch it.
I suspect it is because you tried 1.7.1 first - the default was incorrectly set to “ON”.
You will need to delete your config file from the user profile - roaming section. It will be called XiboClient.config.xml.
cant find such file:/
screenshot: http://gyazo.com/2dfed9a5457513eb746e8e7b1f201974
As Dan said it will be in the Roaming section of your user profile (eg c:\Users\username\AppData\Roaming) - not in the program installation folder.
Sorry, my bad, found it in application data folder (this is win xp).
Thank you very much, everything works now
