A bunch of our devices are spamming the logs with the following errors:
“Unable to insert Player Faults records. SQLSTATE[22001]: String data, right truncated: 1406 Data too long for column ‘reason’ at row 1”
“XMDS returned false when reporting faults.”
" Cannot display video. Uri=file:///data/user/0/uk.org.xibo.client/files/129.mp4. Error=MediaCodecVideoRenderer error, index=0, format=Format(1, null, null, video/avc, avc1.4D4029, -1, null, [1920, 1080, 24.0], [-1, -1]), format_supported=YES. Underlying Error=Decoder init failed: OMX.amlogic.avc.decoder.awesome, Format(1, null, null, video/avc, avc1.4D4029, -1, null, [1920, 1080, 24.0], [-1, -1])." - as far as i can tell with this one, the video still plays
“setNextLayout: Cannot set the next Layout from the Schedule. e: Schedule Invalid: size is 1 " - there is only one layout on the schedule set on an indefinite loop”
My guess is that the layout you’ve got in the schedule has a video on it, and for some reason that video is occasionally not able to be decoded. When that happens it gets removed from the schedule, causing the error message you see to appear.
