Unable to get Weather results
Include the Player type you are using.
NA
Fresh Docker setup on Ubuntu trying to setup the Weather widget. I have signed up fir the API over at openweather. Ive put the API in the configuration on the CMS but when I add a static Weather widget it just shows blank and says Unable to get Eather results. I don’t see any API calls inside openweather so gues itve a config issue somewhere. Can anyone point me in the right direction here?
