Upgrading from 1.8.13 to 2.3.10
Installation Method
Docker
Operating System
Ubuntu 20.04.2
Upgraded following instructions at: https://xibo.org.uk/docs/setup/upgrade-xibo-for-docker-install
Command line portion completed without error, but web interface stuck at: “The CMS is temporarily off-line as an upgrade is in progress. Please check with your system administrator for updates or refresh your page in a few minutes.” - and stuck there overnight.
Output from logs:
ecotspm@tracker:/opt/Xibo/xibo-docker$ docker-compose -f cms_custom-ports.yml logs cms-web
Attaching to xibo-docker_cms-web_1
cms-web_1 | Waiting for MySQL to start - max 300 seconds
cms-web_1 | MySQL started
cms-web_1 | settingId
cms-web_1 | 1
cms-web_1 | Existing Database, checking if we need to upgrade it
cms-web_1 | Phinx by CakePHP - https://phinx.org. 0.9.2
cms-web_1 |
cms-web_1 | using config file .varwwwcmsphinx.php
cms-web_1 | using config parser php
cms-web_1 | using migration paths
cms-web_1 | - /var/www/cms/db/migrations
cms-web_1 | warning no environment specified, defaulting to: production
cms-web_1 | ordering by creation time
cms-web_1 |
cms-web_1 | Status [Migration ID] Started Finished Migration Name
cms-web_1 | ----------------------------------------------------------------------------------
cms-web_1 | up 20180130073838 2021-04-21 17:41:33 2021-04-21 17:41:33 InstallMigration
cms-web_1 | up 20180131113100 2021-04-21 17:41:33 2021-04-21 17:41:33 OldUpgradeStep85Migration
cms-web_1 | up 20180131113853 2021-04-21 17:41:33 2021-04-21 17:41:33 OldUpgradeStep86Migration
cms-web_1 | up 20180131113941 2021-04-21 17:41:33 2021-04-21 17:41:33 OldUpgradeStep87Migration
cms-web_1 | up 20180131113948 2021-04-21 17:41:33 2021-04-21 17:41:33 OldUpgradeStep88Migration
cms-web_1 | up 20180131113952 2021-04-21 17:41:33 2021-04-21 17:41:33 OldUpgradeStep92Migration
cms-web_1 | up 20180131113957 2021-04-21 17:41:34 2021-04-21 17:41:34 OldUpgradeStep120Migration
cms-web_1 | up 20180131114002 2021-04-21 17:41:34 2021-04-21 17:41:34 OldUpgradeStep121Migration
cms-web_1 | up 20180131114007 2021-04-21 17:41:34 2021-04-21 17:41:34 OldUpgradeStep122Migration
cms-web_1 | up 20180131114013 2021-04-21 17:41:34 2021-04-21 17:41:34 OldUpgradeStep123Migration
cms-web_1 | up 20180131114017 2021-04-21 17:41:34 2021-04-21 17:41:34 OldUpgradeStep124Migration
cms-web_1 | up 20180131114021 2021-04-21 17:41:34 2021-04-21 17:41:34 OldUpgradeStep125Migration
cms-web_1 | up 20180131114025 2021-04-21 17:41:34 2021-04-21 17:41:34 OldUpgradeStep126Migration
cms-web_1 | up 20180131114030 2021-04-21 17:41:34 2021-04-21 17:41:34 OldUpgradeStep127Migration
cms-web_1 | up 20180131114050 2021-04-21 17:41:34 2021-04-21 17:41:34 OldUpgradeStep128Migration
cms-web_1 | up 20180131114058 2021-04-21 17:41:35 2021-04-21 17:41:35 OldUpgradeStep129Migration
cms-web_1 | up 20180131114103 2021-04-21 17:41:35 2021-04-21 17:41:35 OldUpgradeStep130Migration
cms-web_1 | up 20180131114107 2021-04-21 17:41:35 2021-04-21 17:41:35 OldUpgradeStep131Migration
cms-web_1 | up 20180131114110 2021-04-21 17:41:35 2021-04-21 17:41:35 OldUpgradeStep132Migration
cms-web_1 | up 20180131114114 2021-04-21 17:41:35 2021-04-21 17:41:35 OldUpgradeStep133Migration
cms-web_1 | up 20180131114118 2021-04-21 17:41:35 2021-04-21 17:41:35 OldUpgradeStep134Migration
cms-web_1 | up 20180131114123 2021-04-21 17:41:35 2021-04-21 17:41:35 OldUpgradeStep135Migration
cms-web_1 | down 20180131122645 OneRegionPerPlaylistMigration
cms-web_1 | down 20180131123038 PlaylistTagsMigration
cms-web_1 | down 20180131123248 WidgetFromToDtMigration
cms-web_1 | down 20180212143336 DaypartSystemEntriesAsRecords
cms-web_1 | down 20180213173846 MailFromNameSettingMigration
cms-web_1 | down 20180219141257 DisplayGroupClosureIndexToNonUnique
cms-web_1 | down 20180223180534 DataSetColumnFilterAndSortOptionsMigration
cms-web_1 | down 20180302182421 WidgetCreatedAndModifiedDtMigration
cms-web_1 | down 20180313085749 MediaTableEditedIdIndexMigration
cms-web_1 | down 20180320154652 PlaylistAddDynamicFilterMigration
cms-web_1 | down 20180327153325 RemoveUserLoggedInMigration
cms-web_1 | down 20180514114415 FixCaseOnHelpTextFieldMigration
cms-web_1 | down 20180515123835 LayoutPublishDraftMigration
cms-web_1 | down 20180529065816 DataSetTruncateFixMigration
cms-web_1 | down 20180529073531 DisplayAsVncLinkMigration
cms-web_1 | down 20180621134013 AddWidgetSyncTaskMigration
cms-web_1 | down 20180621134250 EventLayoutPermissionSettingMigration
cms-web_1 | down 20180906115552 AddForeignKeysToTagsMigration
cms-web_1 | down 20180906115606 AddForeignKeysToPermissionsMigration
cms-web_1 | down 20180906115712 AddForeignKeysToWidgetMediaMigration
cms-web_1 | down 20180906131643 ForgottenPasswordReminderMigration
cms-web_1 | down 20180906131716 DataSetRssMigration
cms-web_1 | down 20181011160130 SimpleSettingsMigration
cms-web_1 | down 20181113173310 RemoveFinanceModuleMigration
cms-web_1 | down 20181113180337 SplitTickerModuleMigration
cms-web_1 | down 20181126113231 Release1812Migration
cms-web_1 | down 20181210092443 RemoveImageUriModuleMigration
cms-web_1 | down 20181212114400 CreatePlayerVersionsTableMigration
cms-web_1 | down 20181217135044 EventSyncMigration
cms-web_1 | down 20190121092556 PlayerUpgradeAndOverrideConfigMigration
cms-web_1 | down 20190125170130 PlayerSoftwareVersionFieldMigration
cms-web_1 | down 20190129103831 AddLinuxDisplayProfileMigration
cms-web_1 | down 20190212112534 AddProofOfPlayStatsDurationAndCountMigration
cms-web_1 | down 20190212115432 AddDefaultTransitionDurationSettingMigration
cms-web_1 | down 20190213160914 AddGlobalStatSettingMigration
cms-web_1 | down 20190213162212 AddHorizontalMenuSettingMigration
cms-web_1 | down 20190214102508 AddLayoutEnableStat
cms-web_1 | down 20190214102516 AddMediaEnableStat
cms-web_1 | down 20190220165703 AddScheduleRecurrenceMonthlyRepeatsOnMigration
cms-web_1 | down 20190227101705 MakeDisplayLicenseColumnUniqueMigration
cms-web_1 | down 20190228120603 AddDynamicCriteriaTagsMigration
cms-web_1 | down 20190301115046 AdjustGenericfileValidExtensionsMigration
cms-web_1 | down 20190315134628 AddBandwidthLimitColumnToDisplaygroupMigration
cms-web_1 | down 20190322162052 AddPublishedDateColumnMigration
cms-web_1 | down 20190326163016 CreateLayoutHistoryTableMigration
cms-web_1 | down 20190328111718 AddCampaignStatMigration
cms-web_1 | down 20190401150256 AddScheduleNowPageMigration
cms-web_1 | down 20190509101525 CreateReportScheduleTableMigration
cms-web_1 | down 20190509102648 CreateSavedReportTableMigration
cms-web_1 | down 20190509113001 AddReportPageMigration
cms-web_1 | down 20190510140126 TwoFactorAuthMigration
cms-web_1 | down 20190514134430 NullableTextFieldsMigration
cms-web_1 | down 20190515094133 AddHtmlDatatypeMigration
cms-web_1 | down 20190515105624 InstallAdditionalStandardModulesMigration
cms-web_1 | down 20190517080033 AddForeignKeysToLktagTablesMigration
cms-web_1 | down 20190521092700 AddReportScheduleTaskMigration
cms-web_1 | down 20190521092930 AddPreviousRunDateReportScheduleMigration
cms-web_1 | down 20190521102635 PlaylistDurationUpdateAtTimestamp
cms-web_1 | down 20190603083836 ChangeStatTableStartEndColumnMigration
cms-web_1 | down 20190610150331 TagsWithValuesMigration
cms-web_1 | down 20190611145607 RemoveOldVersionTableMigration
cms-web_1 | down 20190612140955 DisplayTableDatabaseSchemaAdjustmentsMigration
cms-web_1 | down 20190620112611 MoveTidyStatsToStatsArchiveTaskMigration
cms-web_1 | down 20190620142655 AddPlaylistEnableStatMigration
cms-web_1 | down 20190626091331 WidgetHistoryMigration
cms-web_1 | down 20190626110359 CreateStatTableMigration
cms-web_1 | down 20190628083649 AddStatsMigrationTaskMigration
cms-web_1 | down 20190710213414 AddIsActiveReportScheduleMigration
cms-web_1 | down 20190717101342 NullableCommandValidationStringMigration
cms-web_1 | down 20190719074601 MissingDefaultValueMigration
cms-web_1 | down 20190725115532 AddScheduleReminderTaskMigration
cms-web_1 | down 20190801102042 DisplayProfileCommandLinkFixMigration
cms-web_1 | down 20190801141737 DatasetAddCustomHeadersColumnMigration
cms-web_1 | down 20190801142302 AddDoohUserTypeMigration
cms-web_1 | down 20190802145636 CreateScheduleReminderTableMigration
cms-web_1 | down 20190806144729 AddShowContentFromMigration
cms-web_1 | down 20190823081448 AddImageProcessingTaskMigration
cms-web_1 | down 20190828123735 AddDefaultSettingResizeLimitResizeThresholdMigration
cms-web_1 | down 20190903083314 AddGlobalSettingForCascadePermissionsMigration
cms-web_1 | down 20190905084201 AddSettingForDefaultTransitionTypeMigration
cms-web_1 | down 20190905084642 AddSettingForAutoLayoutPublishMigration
cms-web_1 | down 20190910132520 DisplayMoveCmsMigration
cms-web_1 | down 20190917093141 InterruptLayoutMigration
cms-web_1 | down 20190918090608 AddDefaultSettingQuickChartMigration
cms-web_1 | down 20190919154513 AddNotificationAttachmentFilenameNonUsersMigration
cms-web_1 | down 20190926135518 AddSettingForTransitionAutoApplyToLayoutMigration
cms-web_1 | down 20190926140809 InstallSavedReportsAndSpacerModulesMigration
cms-web_1 | down 20191001092651 AddNotificationOriginalFilenameMigration
cms-web_1 | down 20191022101141 AddCommandEntityToPermissionEntityMigration
cms-web_1 | down 20191024152519 AddScheduleExclusionsTableMigration
cms-web_1 | down 20191122114104 FixDuplicateModuleFilesMigration
cms-web_1 | down 20191126103120 GeoScheduleMigration
cms-web_1 | down 20191126141140 RemoteDataSetCsvSourceMigration
cms-web_1 | down 20191205180116 AddPlaylistDashboardPageUserMigration
cms-web_1 | down 20200107082625 DisplayAddResolutionMigration
cms-web_1 | down 20200115115935 AddReportScheduleMessageMigration
cms-web_1 | down 20200122143630 AddReleasedRequiredFileMigration
cms-web_1 | down 20200122191232 AddCommercialLicenceColumnMigration
cms-web_1 | down 20200129104944 AddEngagementsStatsMigration
cms-web_1 | down 20200130165443 CountdownModuleAddMigration
cms-web_1 |
cms-web_1 | We will upgrade it, take a backup
cms-web_1 | mysqldump: Error: ‘Access denied; you need (at least one of) the PROCESS privilege(s) for this operation’ when trying to dump tablespaces
cms-web_1 | Running database migrations
cms-web_1 |
cms-web_1 | using adapter mysql
cms-web_1 | using database cms
cms-web_1 |
cms-web_1 | == 20180131122645 OneRegionPerPlaylistMigration: migrating
cms-web_1 |
cms-web_1 | In PdoAdapter.php line 134:
cms-web_1 |
cms-web_1 | SQLSTATE[42S21]: Column already exists: 1060 Duplicate column name ‘regionI
cms-web_1 | d’
cms-web_1 |
cms-web_1 |
cms-web_1 | migrate [-c|–configuration CONFIGURATION] [-p|–parser PARSER] [-e|–environment ENVIRONMENT] [-t|–target TARGET] [-d|–date DATE] [-x|–dry-run]
cms-web_1 |
cms-web_1 | cp: can’t stat ‘/var/www/cms/ca-certs/.pem’: No such file or directory
cms-web_1 | cp: can’t stat '/var/www/cms/ca-certs/.crt’: No such file or directory
cms-web_1 | WARNING: ca-certificates.crt does not contain exactly one certificate or CRL: skipping
cms-web_1 | Setting up Quickchart
cms-web_1 | Removing web/install/index.php from production container
cms-web_1 | Starting cron
cms-web_1 | AH00558: httpd: Could not reliably determine the server’s fully qualified domain name, using 172.18.0.5. Set the ‘ServerName’ directive globally to suppress this message
Please advise on how I can complete the migration to 2.3.10.
Thanks,
-Eric
