3.0.6 via Docker on Windows
Windows
3 R301.1
Images not appearing. Neither profile no content photos.
Not showing in CMS preview or on player.
In the logs I seem to be getting “General error: 1366 Incorrect integer value: ‘’ for column ‘fileSize’ at row 1”,ERROR"
When the CMS tries to fetch the images.
See log sample below.
Any idea how to fix?
Thanks!
16556,5f56699,“2022-01-31 15:37:45”,WEB,/playlist/widget/resource/115/236,GET,“Process queue of 1 display notifications”,DEBUG
16557,5f56699,“2022-01-31 15:37:45”,WEB,/playlist/widget/resource/115/236,GET,“Process queue of 1 display actions”,DEBUG
16558,5f56699,“2022-01-31 15:37:45”,WEB,/playlist/widget/resource/115/236,GET,“Player Action Service is looking to send 1 actions”,DEBUG
16559,e9183c7,“2022-01-31 15:37:45”,WEB,/playlist/widget/resource/112/233,GET,“saveFile for "twitter_234137899" [478] with storedAs = "twitter_234137899", fileName = "http://pbs.twimg.com/profile_images/1413643432732528642/w-JJtO0t_bigger.jpg" to "478.jpg". Always Copy = "", Cloned = ""”,DEBUG
16560,e9183c7,“2022-01-31 15:37:45”,WEB,/playlist/widget/resource/112/233,GET,“Moving temporary file: /var/www/cms/library/temp/twitter_234137899”,DEBUG
16561,e9183c7,“2022-01-31 15:37:45”,WEB,/playlist/widget/resource/112/233,GET,“Unable to save:478. SQLSTATE[HY000]: General error: 1366 Incorrect integer value: ‘’ for column ‘fileSize’ at row 1”,ERROR
16562,e9183c7,“2022-01-31 15:37:45”,WEB,/playlist/widget/resource/112/233,GET,“saveFile for "twitter_242061800" [480] with storedAs = "twitter_242061800", fileName = "http://pbs.twimg.com/profile_images/1400572358252011533/s00e0Xt0_bigger.jpg" to "480.jpg". Always Copy = "", Cloned = ""”,DEBUG
16563,e9183c7,“2022-01-31 15:37:45”,WEB,/playlist/widget/resource/112/233,GET,“Moving temporary file: /var/www/cms/library/temp/twitter_242061800”,DEBUG
16564,e9183c7,“2022-01-31 15:37:45”,WEB,/playlist/widget/resource/112/233,GET,“Unable to save:480. SQLSTATE[HY000]: General error: 1366 Incorrect integer value: ‘’ for column ‘fileSize’ at row 1”,ERROR
16565,e9183c7,“2022-01-31 15:37:45”,WEB,/playlist/widget/resource/112/233,GET,“saveFile for "twitter_2431204724" [476] with storedAs = "twitter_2431204724", fileName = "http://pbs.twimg.com/profile_images/1364447894783229960/yxInefMw_bigger.jpg" to "476.jpg". Always Copy = "", Cloned = ""”,DEBUG
16566,e9183c7,“2022-01-31 15:37:45”,WEB,/playlist/widget/resource/112/233,GET,“Moving temporary file: /var/www/cms/library/temp/twitter_2431204724”,DEBUG
16567,e9183c7,“2022-01-31 15:37:45”,WEB,/playlist/widget/resource/112/233,GET,“Unable to save:476. SQLSTATE[HY000]: General error: 1366 Incorrect integer value: ‘’ for column ‘fileSize’ at row 1”,ERROR
16568,3cb82e9,“2022-01-31 15:37:45”,WEB,/library/fontcss,GET,“Loading 1. All Objects = 0”,DEBUG
16569,3cb82e9,“2022-01-31 15:37:45”,WEB,/library/fontcss,GET,“Install Fonts called with options: {"invalidateCache":false}”,DEBUG
16570,3cb82e9,“2022-01-31 15:37:45”,WEB,/library/fontcss,GET,“CMS font CSS returned from Cache.”,DEBUG
16571,3cb82e9,“2022-01-31 15:37:45”,WEB,/library/fontcss,GET,“Install Fonts called with options: {"invalidateCache":false}”,DEBUG
16572,3cb82e9,“2022-01-31 15:37:45”,WEB,/library/fontcss,GET,“CMS font CSS returned from Cache.”,DEBUG
16573,e9183c7,“2022-01-31 15:37:45”,WEB,/playlist/widget/resource/112/233,GET,“saveFile for "twitter_photo_234137899" [479] with storedAs = "twitter_photo_234137899", fileName = "http://pbs.twimg.com/media/FKcFkCrX0AEjm-J.jpg" to "479.jpg". Always Copy = "", Cloned = ""”,DEBUG
16574,3cb82e9,“2022-01-31 15:37:45”,WEB,/library/fontcss,GET,“Request stats: {
"default": {
"select": 6
"log": {
"insert": 5
"length": 0.09920310974121094,
"memoryUsage": 18306512,
"peakMemoryUsage": 18477344
}.”,INFO
