One of my users is having some trouble with the twitter module of xibo.
When they use the twitter option in the timeline nothing will show up in the preview or on the active displays.
We’re running 1.7.0 on both server and clients, all I can see in the logs at the moment is:
15677 2015-03-24 09:18:18 CMS Twitter getToken Twitter Error: Unknown Error
15675 2015-03-24 09:18:18 CMS Twitter getToken Twitter API returned status. Unable to proceed.
15613 2015-03-24 09:17:04 CMS Twitter getToken Bearer Token served from API
15611 2015-03-24 09:17:04 CMS Twitter getTwitterFeed Querying API for chew valley school
I’ve just finished upgrading the server and clients to 1.7.2, now i get:
76529 15-03-24 04:32:09 CMS Twitter getToken Error contacting Twitter API: SSL certificate problem, verify that the CA cert is OK. Details:
error:14090086:SSL routines:SSL3_GET_SERVER_CERTIFICATE:certificate verify failed
We haven’t written a guide yet as the module is fairly new - as you can see the manual page is very bare indeed!
The search API in twitter works on search terms - so you need to specify the search string on the twitter module. That will cut down the results accordingly.
