Is there a way to get the following functionality?
Layout 1 is shown by default, this is a website widget with Touch interface.
If no action (touch) is made, after 90 seconds Layout 2 is shown, until a touch action triggers Layout 1 again.
You can, on windows anyway use the system screensaver and install the xibo scr. You could have your screensaver layout be the main layout, then use an interrupt layout when there is activity on the input devices.
This is a Windows-only workaround.
It should be possible to do this for all devices, by adding an option to the layout triggers.
It’s not the first time I’ve seen this request.
Maybe we need to set layout 2 as the default and give it a trigger action to display layout 1 ![]()
Can you please explain this in more.
