Transition between Playlist Elements
I’m currently experiencing an issue with the transition feature in a playlist. We are displaying a Dashboard webpage that is supposed to transition to the Microsoft Status webpage after a certain time.
Problem: The transition only works with the Dashboard fading out. At the beginning and ending of the playlist there are no transitions.
The assigned transitions are both Fade In & Out, both set to 1000ms
Is there something I’m doing wrong?
