Is it possible to use a touchscreen (Iiyama) connected with the DSCS9 player (connected via USB) and XIBO software? The player is showing a webpage with buttons.
(the customer is now using a Windows NUC with a touchscreen and XIBO with a webpage, this is working perfect, and now wants more screens)
Thank you for your message. The Xibo Players do not officially support interactivity. You may find that connecting a touchscreen to the DSCS9 will work but performance cannot be guaranteed.
You would need to test connecting a touchscreen to your DSCS9 to know if it works as you would like. You may also find more information about the hardware compatibility with your touchscreen.
