Tizen Video-In element on Xibo Layout
Are there specific series of monitors that work or don’t work with the Video-In widget? CMS 4.3
Tizen for Xibo 408
Hi Jon, all supported Tizen displays should work with the video in widget, HDMI 1 only. Although it’s worth noting that SSSP 5 displays generally are not supported with the latest v4 players so it would be best to use SSSP 6 or newer.
We are also investigating a potential issue for Video in via Display Port which we have been notified as not working on a QM55C for R408, but that does still work with HDMI 1.
It’s quite strange the behavior I am seeing. When i run the video in feed running the Xibo application, the video-in only shows properly if the display is in landscape mode. If I run magicinfo instead of xibo I am able to do both portrait and landscape using Magic Info WebAuthor and a video-in element. The displays being used are OH55A-S
Hi Jon, could you open a support ticket so that we can take a further look? I have given them the heads up to look out for it.
Thank you
