i have a problem to use local or remote Rss. let me explain.
I have created a very basic rss.xml file to load a message “welcome” on my DSCS95 and before on a rasbery with android ARM version. All was fine since One year.
In summary
- 1 CMS installed from Docker Compose on Llinux Ubuntu server (Local Network)
- 1 DSCS95 installed (Local Network)
- 1 Rss.xml file on IIS Windows server containing a virtual folder
Note : no firewall on the LAN. no firewall on the servers. DNS resolution works fine on every devices
and all fqdn works. Ntp works correctly all devices are synchronized
But, since two weeks without any change the Rss flux stopped. I have checked everything i know
but nothing. i have changed fqdn url ticker by the ip address but it don’t work.
Ok i assume my version of CMS was not up to date and i assume to upgrade to 3.3.2. After a long time of loneliness to update CMS. Finaly in 3.3.2 version. My first action was to check if my Ticker problem was solved. Nope. Same problem. Same errors
here what i found in the CMD logs for DSCS95 device and on CMS (layout creation)
Case 1 : when using FQDN url http://servername.fqdn/rss/rss.xml
Error: Curl Error 6 : Could not resolve host. The given remote host was not resolved.
note : When i use the rss url on web page the rss.xml works
Case 2 : when using IPaddress url http://x.x.x.x/rss/rss.xml
Error: cURL error 28: Connection timed out after 20001 milliseconds
I going to be crazy
Please someone HELP !
