Windows
3 R301.1
Ticker is not showing images after upgrade to Xibo version 3. So i tried a fresh install, but still same issue. Tested with different RSS feeds but alway nog images. The only thing i see is de JPG icon in the corner of the preview or player.
RSS feed: VRT NWS: nieuws
Modules have been verified.
Also, making changes tot de module cannot be done. After saving it trows an error:
Argument 1 passed to Respect\Validation\Rules\AbstractComposite::addRules() must be of the type array, null given, called in /var/www/cms/vendor/xibosignage/support/src/Xibo/Support/Sanitizer/RespectSanitizer.php on line 124
Hi, have you selected a Template from the Preset options? If so which one are you using?
What configuration options have you entered, so that I can try and recreate the issue you are seeing?
Thank you
Hi natasha,
Here is my configuration:
Log:
19554
ff24516
23-08-2021 12:57
WEB
GET
DEBUG
/library/download/2418/image
#0 /var/www/cms/lib/Controller/Library.php(1498): Xibo\Factory\MediaFactory->getById(‘2418’) #1 [internal function]: Xibo\Controller\Library->download(Object(Slim\Http\ServerRequest), Object(Slim\Http\Response)) #2 /var/www/cms/vendor/php-di/invoker/src/Invoker.php(82): call_user_func_array(Array, Array) #3 /var/www/cms/vendor/php-di/slim-bridge/src/ControllerInvoker.php(47): Invoker\Invoker->call(Array, Array) #4 /var/www/cms/vendor/slim/slim/Slim/Routing/Route.php(384): DI\Bridge\Slim\ControllerInvoker->__invoke(Array, Object(Slim\Http\ServerRequest), Object(Slim\Http\Response), Array) #5 /var/www/cms/vendor/slim/slim/Slim/MiddlewareDispatcher.php(81): Slim\Routing\Route->handle(Object(Slim\Http\ServerRequest)) #6 /var/www/cms/vendor/slim/slim/Slim/MiddlewareDispatcher.php(81): Slim\MiddlewareDispatcher->handle(Object(Slim\Http\ServerRequest)) #7 /var/www/cms/vendor/slim/slim/Slim/Routing/Route.php(341): Slim\MiddlewareDispatcher->handle(Object(Slim\Http\ServerRequest)) #8 /var/www/cms/vendor/slim/slim/Slim/Routing/RouteRunner.php(84): Slim\Routing\Route->run(Object(Slim\Http\ServerRequest)) #9 /var/www/cms/vendor/akrabat/ip-address-middleware/src/IpAddress.php(91): Slim\Routing\RouteRunner->handle(Object(Slim\Http\ServerRequest)) #10 /var/www/cms/vendor/slim/slim/Slim/MiddlewareDispatcher.php(147): RKA\Middleware\IpAddress->process(Object(Slim\Http\ServerRequest), Object(Slim\Routing\RouteRunner)) #11 /var/www/cms/lib/Middleware/Actions.php(176): class@anonymous->handle(Object(Slim\Http\ServerRequest)) #12 /var/www/cms/vendor/slim/slim/Slim/MiddlewareDispatcher.php(147): Xibo\Middleware\Actions->process(Object(Slim\Http\ServerRequest), Object(class@anonymous)) #13 /var/www/cms/lib/Middleware/Theme.php(70): class@anonymous->handle(Object(Slim\Http\ServerRequest)) #14 /var/www/cms/vendor/slim/slim/Slim/MiddlewareDispatcher.php(147): Xibo\Middleware\Theme->process(Object(Slim\Http\ServerRequest), Object(class@anonymous)) #15 /var/www/cms/lib/Middleware/CsrfGuard.php(121): class@anonymous->handle(Object(Slim\Http\ServerRequest)) #16 /var/www/cms/vendor/slim/slim/Slim/MiddlewareDispatcher.php(147): Xibo\Middleware\CsrfGuard->process(Object(Slim\Http\ServerRequest), Object(class@anonymous)) #17 /var/www/cms/lib/Middleware/AuthenticationBase.php(76): class@anonymous->handle(Object(Slim\Http\ServerRequest)) #18 /var/www/cms/vendor/slim/slim/Slim/MiddlewareDispatcher.php(147): Xibo\Middleware\AuthenticationBase->process(Object(Slim\Http\ServerRequest), Object(class@anonymous)) #19 /var/www/cms/lib/Middleware/State.php(87): class@anonymous->handle(Object(Slim\Http\ServerRequest)) #20 /var/www/cms/vendor/slim/slim/Slim/MiddlewareDispatcher.php(147): Xibo\Middleware\State->process(Object(Slim\Http\ServerRequest), Object(class@anonymous)) #21 /var/www/cms/lib/Middleware/Log.php(59): class@anonymous->handle(Object(Slim\Http\ServerRequest)) #22 /var/www/cms/vendor/slim/slim/Slim/MiddlewareDispatcher.php(147): Xibo\Middleware\Log->process(Object(Slim\Http\ServerRequest), Object(class@anonymous)) #23 /var/www/cms/vendor/slim/twig-view/src/TwigMiddleware.php(125): class@anonymous->handle(Object(Slim\Http\ServerRequest)) #24 /var/www/cms/vendor/slim/slim/Slim/MiddlewareDispatcher.php(147): Slim\Views\TwigMiddleware->process(Object(Slim\Http\ServerRequest), Object(class@anonymous)) #25 /var/www/cms/lib/Middleware/Storage.php(61): class@anonymous->handle(Object(Slim\Http\ServerRequest)) #26 /var/www/cms/vendor/slim/slim/Slim/MiddlewareDispatcher.php(147): Xibo\Middleware\Storage->process(Object(Slim\Http\ServerRequest), Object(class@anonymous)) #27 /var/www/cms/lib/Middleware/Xmr.php(67): class@anonymous->handle(Object(Slim\Http\ServerRequest)) #28 /var/www/cms/vendor/slim/slim/Slim/MiddlewareDispatcher.php(147): Xibo\Middleware\Xmr->process(Object(Slim\Http\ServerRequest), Object(class@anonymous)) #29 /var/www/cms/vendor/slim/slim/Slim/Middleware/RoutingMiddleware.php(59): class@anonymous->handle(Object(Slim\Http\ServerRequest)) #30 /var/www/cms/vendor/slim/slim/Slim/MiddlewareDispatcher.php(147): Slim\Middleware\RoutingMiddleware->process(Object(Slim\Http\ServerRequest), Object(class@anonymous)) #31 /var/www/cms/vendor/slim/slim/Slim/Middleware/ErrorMiddleware.php(107): class@anonymous->handle(Object(Slim\Http\ServerRequest)) #32 /var/www/cms/vendor/slim/slim/Slim/MiddlewareDispatcher.php(147): Slim\Middleware\ErrorMiddleware->process(Object(Slim\Http\ServerRequest), Object(class@anonymous)) #33 /var/www/cms/vendor/slim/slim/Slim/MiddlewareDispatcher.php(81): class@anonymous->handle(Object(Slim\Http\ServerRequest)) #34 /var/www/cms/vendor/slim/slim/Slim/App.php(215): Slim\MiddlewareDispatcher->handle(Object(Slim\Http\ServerRequest)) #35 /var/www/cms/vendor/slim/slim/Slim/App.php(199): Slim\App->handle(Object(Slim\Http\ServerRequest)) #36 /var/www/cms/web/index.php(128): Slim\App->run() #37 {main}
19553
40438ae
23-08-2021 12:57
WEB
GET
DEBUG
/library/download/2419/image
#0 /var/www/cms/lib/Controller/Library.php(1498): Xibo\Factory\MediaFactory->getById(‘2419’) #1 [internal function]: Xibo\Controller\Library->download(Object(Slim\Http\ServerRequest), Object(Slim\Http\Response)) #2 /var/www/cms/vendor/php-di/invoker/src/Invoker.php(82): call_user_func_array(Array, Array) #3 /var/www/cms/vendor/php-di/slim-bridge/src/ControllerInvoker.php(47): Invoker\Invoker->call(Array, Array) #4 /var/www/cms/vendor/slim/slim/Slim/Routing/Route.php(384): DI\Bridge\Slim\ControllerInvoker->__invoke(Array, Object(Slim\Http\ServerRequest), Object(Slim\Http\Response), Array) #5 /var/www/cms/vendor/slim/slim/Slim/MiddlewareDispatcher.php(81): Slim\Routing\Route->handle(Object(Slim\Http\ServerRequest)) #6 /var/www/cms/vendor/slim/slim/Slim/MiddlewareDispatcher.php(81): Slim\MiddlewareDispatcher->handle(Object(Slim\Http\ServerRequest)) #7 /var/www/cms/vendor/slim/slim/Slim/Routing/Route.php(341): Slim\MiddlewareDispatcher->handle(Object(Slim\Http\ServerRequest)) #8 /var/www/cms/vendor/slim/slim/Slim/Routing/RouteRunner.php(84): Slim\Routing\Route->run(Object(Slim\Http\ServerRequest)) #9 /var/www/cms/vendor/akrabat/ip-address-middleware/src/IpAddress.php(91): Slim\Routing\RouteRunner->handle(Object(Slim\Http\ServerRequest)) #10 /var/www/cms/vendor/slim/slim/Slim/MiddlewareDispatcher.php(147): RKA\Middleware\IpAddress->process(Object(Slim\Http\ServerRequest), Object(Slim\Routing\RouteRunner)) #11 /var/www/cms/lib/Middleware/Actions.php(176): class@anonymous->handle(Object(Slim\Http\ServerRequest)) #12 /var/www/cms/vendor/slim/slim/Slim/MiddlewareDispatcher.php(147): Xibo\Middleware\Actions->process(Object(Slim\Http\ServerRequest), Object(class@anonymous)) #13 /var/www/cms/lib/Middleware/Theme.php(70): class@anonymous->handle(Object(Slim\Http\ServerRequest)) #14 /var/www/cms/vendor/slim/slim/Slim/MiddlewareDispatcher.php(147): Xibo\Middleware\Theme->process(Object(Slim\Http\ServerRequest), Object(class@anonymous)) #15 /var/www/cms/lib/Middleware/CsrfGuard.php(121): class@anonymous->handle(Object(Slim\Http\ServerRequest)) #16 /var/www/cms/vendor/slim/slim/Slim/MiddlewareDispatcher.php(147): Xibo\Middleware\CsrfGuard->process(Object(Slim\Http\ServerRequest), Object(class@anonymous)) #17 /var/www/cms/lib/Middleware/AuthenticationBase.php(76): class@anonymous->handle(Object(Slim\Http\ServerRequest)) #18 /var/www/cms/vendor/slim/slim/Slim/MiddlewareDispatcher.php(147): Xibo\Middleware\AuthenticationBase->process(Object(Slim\Http\ServerRequest), Object(class@anonymous)) #19 /var/www/cms/lib/Middleware/State.php(87): class@anonymous->handle(Object(Slim\Http\ServerRequest)) #20 /var/www/cms/vendor/slim/slim/Slim/MiddlewareDispatcher.php(147): Xibo\Middleware\State->process(Object(Slim\Http\ServerRequest), Object(class@anonymous)) #21 /var/www/cms/lib/Middleware/Log.php(59): class@anonymous->handle(Object(Slim\Http\ServerRequest)) #22 /var/www/cms/vendor/slim/slim/Slim/MiddlewareDispatcher.php(147): Xibo\Middleware\Log->process(Object(Slim\Http\ServerRequest), Object(class@anonymous)) #23 /var/www/cms/vendor/slim/twig-view/src/TwigMiddleware.php(125): class@anonymous->handle(Object(Slim\Http\ServerRequest)) #24 /var/www/cms/vendor/slim/slim/Slim/MiddlewareDispatcher.php(147): Slim\Views\TwigMiddleware->process(Object(Slim\Http\ServerRequest), Object(class@anonymous)) #25 /var/www/cms/lib/Middleware/Storage.php(61): class@anonymous->handle(Object(Slim\Http\ServerRequest)) #26 /var/www/cms/vendor/slim/slim/Slim/MiddlewareDispatcher.php(147): Xibo\Middleware\Storage->process(Object(Slim\Http\ServerRequest), Object(class@anonymous)) #27 /var/www/cms/lib/Middleware/Xmr.php(67): class@anonymous->handle(Object(Slim\Http\ServerRequest)) #28 /var/www/cms/vendor/slim/slim/Slim/MiddlewareDispatcher.php(147): Xibo\Middleware\Xmr->process(Object(Slim\Http\ServerRequest), Object(class@anonymous)) #29 /var/www/cms/vendor/slim/slim/Slim/Middleware/RoutingMiddleware.php(59): class@anonymous->handle(Object(Slim\Http\ServerRequest)) #30 /var/www/cms/vendor/slim/slim/Slim/MiddlewareDispatcher.php(147): Slim\Middleware\RoutingMiddleware->process(Object(Slim\Http\ServerRequest), Object(class@anonymous)) #31 /var/www/cms/vendor/slim/slim/Slim/Middleware/ErrorMiddleware.php(107): class@anonymous->handle(Object(Slim\Http\ServerRequest)) #32 /var/www/cms/vendor/slim/slim/Slim/MiddlewareDispatcher.php(147): Slim\Middleware\ErrorMiddleware->process(Object(Slim\Http\ServerRequest), Object(class@anonymous)) #33 /var/www/cms/vendor/slim/slim/Slim/MiddlewareDispatcher.php(81): class@anonymous->handle(Object(Slim\Http\ServerRequest)) #34 /var/www/cms/vendor/slim/slim/Slim/App.php(215): Slim\MiddlewareDispatcher->handle(Object(Slim\Http\ServerRequest)) #35 /var/www/cms/vendor/slim/slim/Slim/App.php(199): Slim\App->handle(Object(Slim\Http\ServerRequest)) #36 /var/www/cms/web/index.php(128): Slim\App->run() #37 {main}
19552
ff24516
23-08-2021 12:57
WEB
GET
ERROR
Cannot find media
19551
40438ae
23-08-2021 12:57
WEB
GET
ERROR
Cannot find media
system
Closed
November 22, 2021, 6:04pm
5
