I have created a test campaign with different layouts. The only thing that does not work is the ticker from and RSS feed. Is there a trick to get this to work? THanks
Have you worked through the examples in the manual?
http://xibo.org.uk/manual/en/media_module_ticker.html
Try with the Xibo feed first (http://xibo.org.uk/feed) as sometimes feeds are broken or formatted badly.
If you can’t get it working, then some information on exactly how you’ve got things setup would be needed to help you further
Alex
