The Library Location you have picked is not writeable
Version 4.1.1
Installation Method
Docker
Operating System
ubuntu 24
not sure what is the path for the libaray. what to set under library location under the settings?
I tried to following some old topics nothing is working, I created folders, in differnt locations, like:
/var/www/mytv/
and
/opt/mytv/
then changed the folders to 755
still says not writeable
Please help.
Provide screenshots where possible!
The path for the library location is defined in your config.env and the default location is /opt/xibo
Edit: The Library storage can be found in /shared/cms/library
Can you post the output as described here?
Also read this:
Hi I check the config.env there is no location set there.
also under /shared/cms/library there are only 2 folders there.
temp
certs
if I set the path to:
/shared/cms/library
or
/opt/xibo/shared/cms/library/
I got:
Do I need to apply:
chown -R www-data:www-data /opt/xibo/shared/cms/library/
and
chmod -R 777 /opt/xibo/shared/cms/library/
Hello, anyone can help, ad direct me here. nothig is getting working
Got it, the solution is:
to set it as: ./shared/cms/library/
must have . before /
Thank you
