Template filter BUGS?
I want to filter templates with name but name filter doesn’t work. And when filter is done with tags, tags can not be displayed in the table and there is layout name instead of template name.
Also tag filtering does not work. When I use it, all layout are listed.
Which version are you using?
I am using Xibo 1.7.4.
Thanks. I see the same on a test CMS.
I’ll get both issues logged up.
