Task don´t run in Docker installation
4.0.13 (Docker Installation)
Xibo for Windows
v4 R402.1
I have the problem with a freshly installed CMS on a Ubuntu docker, that the tasks won´t run at all.
They are all with their default settings and I only importet a Layout an added a display to test.
Sadly I have no clue why the tasks don´t run since there is nothing to configure that way after the install.
I hope you guys can help me since I am really confused and can´t think of any possible solution.
Check that your MySQL password doesn’t have any $#/ characters in it.
If it does , since it’s a virgin install change it to a password of just upper & lower characters on a new instance and it should work.
When a task hits the MySQL password with a space or non alpha numeric it truncates the password and the job fails
Thank you so much :smiley:
Now that Tasks are running
