Hi.
I’m thinking of creating a system for client management and payments to integrate it into xibo. What do you think?
Where do I find some documentation that contains information about the database and the function of each table?
Thank you.
Hi.
Thank you.
If you want to integrate anything with Xibo, you should do that integration via the API. You should not directly reference or modify the database.
