Synchronization problem with calendar
I just realized that the agenda widget has changed with the new Xibo update, and I’m encountering issues with the new calendar widget. I now use the elements of the calendar widget, such as summary, description, and windows, to create text zones that retrieve data from my Google Calendar using the private iCal key. The problem is that I’ve tried to modify the option to instruct the text zones to refresh every minute, but despite that, when I make changes in Google Calendar, there is no update in Xibo. The only way I found for Xibo to acknowledge the changes is to generate a new private iCal key for Google Calendar and update it in the text zone configuration.
I am having the same issue. Were you able to find a solution?
