Synchronised events locked
Docker 4.1.
Android
v4 R404
This installation no longer allows me to manage the sync events, it is not possible to save the settings, see figure.
When I click on ‘Save’, nothing happens. And the window does not close with the settings saved.
Thank you for posting, I have passed to the team for further investigation.
Update
An issue has been created for this with a target resolution for v4.1.1.
May I add that there seems to be no form validation happening. I.e if you don’t give the sync event a name or don’t add a display group, if you hit save, no errors are shown.
Thanks Jon, I believe that is all addressed in the above issue.
Thank you Natasha,
with the dockerized version 4.1.1, everything seems to be working.
Awesome!
