Can I make a suggestion that the colors used to represent displays in the Displays menu are updated?
Currently, when the displays page has loaded some Displays will be downloading at the time of page load and the Displays menu will show a different set of displays in yellow every time the page is refreshed.
This causes confusion, as yellow makes it appear there is something wrong with the display when it only du to the page loading at the time the player was downloading.
So I suggest the following (open for comment):
- Displays that are logged in and up to date should be green.
- Displays that are logged in and downloading content should also be green (as it’s normal at this stage).
- Displays that are not logged in, or have a bad status should be yellow or red.
Thoughts?
