Strange ZeroMQ problem on PHP 7.2.34
v3.3.11
Installation Method
Custom install on IIS with PHP 7.2.34
Operating System
Windows Server 2019
ZeroMQ not working correctly on my Xibo Installation. When I run a “Report fault” Wizard the ZeroMQ seems apparently Installed correctly. But when I try to use Purge All command on my Windows player an error message appeared “ZeroMQ is required to send Player Actions. Please check your configuration.”
The XMR seems works when I checked the Windows Player R310.1
