Introduction
Stock module shows positive change (change percentage) of a stock when it should show negative and vice-versa
User Story
I display the stock value of TSE:CAE and when the value is during the day, the display shows a negative percentage of change.
For the dev team to fill in:
Status
The current status and the username of the:
- Reporter
- Drafter
- Implementer
Implementation
A broad description of the changes required.
Effected Software
Which parts of Xibo are effected
DB Schema Changes
Any necessary DB Schema Changes
