Stats Archive Task is not cleaning up the stat table
Not Applicable
Not Applicable
Even though the stats archive task is scheduled and claims to be running, the stat table is huge (533080126 rows) and it goes back to early 2020. This is what the web UI has for the task:
Active: 1
Status: 2
Next Run: 9/22/24 20:00
Run Now: 0
Last Run: 9/15/24 20:00
Last Status: 4
Last Duration: 36
We don’t need the data so we can simply truncate the table via command line if we must, but not sure why it has not been able to honor the Max Statistics Age (30 days) we have set under the Maintenance section. Is there perhaps a way to make it so the table only goes back to 30 days?
Thanks,
