i use xibo 1.7.9
i have problem ssl
it post
The request was aborted: Could not create SSL/TLS secure channel
how to fix it?
Xibo 1.7.9 is no longer supported (by years and years!) so I would recommend you upgrade as a matter of urgency.
I think this is likely to be an installation/web server problem rather than a Xibo problem, so I will move it into CMS install questions category.
