Sql Error in the logs.
run: SQLSTATE[22003]: Numeric value out of range: 1264 Out of range value for column ‘mediaId’ at row 1 Exception Type: PDOException
The above error is showing in the log view on the CMS
I’ve migrated the database from mysql5.7 to 8 using mysqldump, is there a database upgrade script I need to run?
Sorry, found the answer to this one. however when I run this I get an authorization error. it doesn’t look like the users have been brought across from the 5.7 install. I think I’m going mad now!
I got the database migrated to mysql 8 (eventually.) and I’ve run the upgrade script against the db/ I’ll keep an eye on the logs. Thank you for your assistance.
1264 d7a3980 2024-03-21 11:40 CONSOLE GET ERROR run: SQLSTATE[22003]: Numeric value out of range: 1264 Out of range value for column 'mediaId' at row 1 Exception Type: PDOException
1263 48212cc 2024-03-21 11:30 CONSOLE GET ERROR run: SQLSTATE[22003]: Numeric value out of range: 1264 Out of range value for column 'mediaId' at row 1 Exception Type: PDOException
1106 4798487 2024-03-21 11:20 CONSOLE GET ERROR run: SQLSTATE[22003]: Numeric value out of range: 1264 Out of range value for column 'mediaId' at row 1 Exception Type: PDOException
all of the tasks are running ok, looking at them, I’m guessing it has something to do with statistics migration or fetching remote datasets.
ID Name Active Status Next Run Run Now Last Run Last Status Last Duration
14 Media Orientation 2024-03-13 11:00 2024-03-13 10:56 0:00:01
17 Widget Compatibility 2024-03-13 10:57 2024-03-13 10:56 0:00:00
4 Stats Archive 2024-03-18 00:00 2024-03-13 10:56 0:00:54
1 Daily Maintenance 2024-03-21 00:00 2024-03-20 00:19 0:19:19
5 Remove old Notifications 2024-03-22 00:15 2024-03-21 09:05 0:00:00
13 Remove Old Screenshots 2024-03-22 00:00 2024-03-21 09:05 0:00:00
15 Purge List Cleanup 2024-03-22 00:00 2024-03-21 09:05 0:00:00
6 Fetch Remote DataSets 2024-03-21 12:30 2024-03-21 11:30 0:00:00
10 Statistics Migration 2024-03-21 11:50 2024-03-21 11:40 0:02:23
3 Email Notifications 2024-03-21 11:50 2024-03-21 11:45 0:00:00
2 Regular Maintenance 2024-03-21 11:50 2024-03-21 11:45 0:00:00
9 Report Schedule 2024-03-21 11:50 2024-03-21 11:45 0:00:00
11 Schedule Reminder 2024-03-21 11:50 2024-03-21 11:45 0:00:00
12 Image Processing 2024-03-21 11:50 2024-03-21 11:45 0:00:00
16 Campaign Scheduler 2024-03-21 12:45 2024-03-21 11:45 0:00:00
8 Sync Dynamic Playlists 2024-03-21 11:49 2024-03-21 11:48 0:00:00
7 Widget Sync 2024-03-21 11:50 2024-03-21 11:48 0:00:02
These are the only errors appearing in the event logs now.
This says stats collection is disabled, I’m not sure if it has been on in the past, but happy to drop or clean up any of this info from the database if you can tell me how.
