Source code for Screensaver
Hi guys,
any ideas where i could get the source code of the Screensaver part?
I have the player source code but i can’t find the screensaver source code (Xibo.SCR)
However,
my question would be to change the image that is displayed in it and was wondering about how to do it…
-daniel
http://xibo.org.uk/manual/en/install_windows_client_screensaver.html
So, when you install the screensaver you configure it as a kind of ‘new’ client on your PC.
Which means you can configure different splash screen for it and specify the layout that should be displayed.
Thanks Peter!
This is clear :slight_smile:
-daniel
