here i want to publish some Code-snippets that i use. Maybe it helps someone.
- Display UV-Index
<center><span style="font-size:45px"> The current UV-Index is:</span></center> <br> <br> <center> <span style="font-size:70px"> <script type="text/javascript"> var uvin; uvin ='[uvIndex]'; switch (uvin) { case '1': document.write("<b><span style=color:#00c800>" + uvin + "</span> <b>"); break; case "2": document.write("<b><span style=color:#00c800>" + uvin + "</span> <b>"); break; case "3": document.write("<b><span style=color:#f8f800>" + uvin + "</span> <b>"); break; case "4": document.write("<b><span style=color:#f8f800>" + uvin + "</span> <b>"); break; case "5": document.write("<b><span style=color:#f8f800>" + uvin + "</span> <b>"); break; case "6": document.write("<b><span style=color:#FFA500>" + uvin + "</span> <b>"); break; case "7": document.write("<b><span style=color:#FFA500>" + uvin + "</span> <b>"); break; case "8": document.write("<b><span style=color:#ec0000>" + uvin + "</span> <b>"); break; case "9": document.write("<b><span style=color:#ec0000>" + uvin + "</span> <b>"); break; case "10": document.write("<b><span style=color:#ec0000>" + uvin + "</span> <b>"); break; } </script> </span> </center> <br>
- Covert Windspeed from Km/h to Windforce
> <center><span style="font-size:45px"> Windspeed:</span></center> > <br> > <br> > <center> > <span style="font-size:70px"> > <script type="text/javascript"> > var windspeed; > windspeed ='[windSpeed]'; > > if (windspeed <=1.85) {document.write("<b><span style=color:#ffffff>0</span> <b>")}; > if (windspeed >=1.85 && windspeed <=7.41) {document.write("<b><span style=color:#ECECFF>1</span> <b>")}; > if (windspeed >=7.41 && windspeed <=12.96) {document.write("<b><span style=color:#D9D9FF>2</span> <b>")}; > if (windspeed >=12.96 && windspeed <=20.37) {document.write("<b><span style=color:#C5C5FF>3</span> <b>")}; > if (windspeed >=20.37 && windspeed <=29.63) {document.write("<b><span style=color:#B0B0FF>4</span> <b>")}; > if (windspeed >=29.63 && windspeed <=40.74) {document.write("<b><span style=color:#9B9BFF>5</span> <b>")}; > if (windspeed >=40.74 && windspeed <=51.86) {document.write("<b><span style=color:#8383FF>6</span> <b>")}; > if (windspeed >=51.86 && windspeed <=62.97) {document.write("<b><span style=color:#6868FF>7</span> <b>")}; > if (windspeed >=62.97 && windspeed <=75.93) {document.write("<b><span style=color:#6868FF>8</span> <b>")}; > if (windspeed >=75.93 && windspeed <=88.90) {document.write("<b><span style=color:#0000FF>9</span> <b>")}; > if (windspeed >=88.90 && windspeed <=103.71) {document.write("<b><span style=color:#0000BB>10</span> <b>")}; > if (windspeed >=103.71 && windspeed <=118.53) {document.write("<b><span style=color:#000077>11</span> <b>")}; > if (windspeed >=118.53) {document.write("<b><span style=color:#000000>12</span> <b>")}; > </script> > </span> > </center>
Greetings Torsten
