i postet it as comment in the release announcement. But here is the better Place for this. Sorry for double Posting. I try to delete the other one
Android and Windows
v3 and v4
If one of the MenuBoard Slots has no animation effect, (see in the picture below the Price). All other information changing but the one without effect staying at the old value. (And changing random)
The default duration of this canvas widget is now set to 1 to avoid this issue. To solve for your layout you need to select a “global element” which is one of the elements from inside the “T” toolbar (text, shape, etc) and then go to the advanced properties and set a duration.
Do you have your HTML in both cases available? I think its likely to be something in the HTML causing it to not break. Probably one paragraph is forcing the width wider because it can’t break for some reason (its not obvious what that might be from your screenshot though).
Where would the back button take you?
I guess this would ignore the “refresh” setting, but obey all other settings?
EDIT: I forgot to say i’ve raised the bugs in menu boards for investigation!
great thanks! i had to add an element from the “T” because i had only dynamic elements now my layout has a empty text and only 20 seconds. Thank you very much!
i respond to the other things later. But i did find another bug:
https://www.wackershofen.de/feed/events
here, it is not possible to show the image in RSS elements. Or i am to stupid the image is empty
This feed doesn’t have any images inside it - just directly referenced HTML. Xibo doesn’t have anything it can pull down in that case - you should be able to show the HTML though (which would include the images).
Ok thank you very much. My mistake also the html thing. I try to find a solution.
Another thing is: I have a calendar in a layout. I group things and want to duplicate it the 3rd time. it works twice. But not on the third one. (on the picture the first slot isn’t a group)
Could you kindly provide us with an export of the layout containing the MenuBoard that you are experiencing issues with? We have been unable to replicate the issues on our end. Thank you.
another funny thing:
If i have a concat formular in datasets, the Word “table” disapears magically so my workaround is to part the word in two strings:
