Hi!
Running Version 3.0.3, Windows player downloads all the files but won’t start:
Any hint?
Thank you so much!
Hi!
Any hint?
Thank you so much!
Just solved it!
So the player didn’t show any logs…
I activated the audit at the Advanced View in the player options at the CMS.
After that the log showed me "“Player has invalid default Layout.”
So ended up investigating the reason and saw that the template was not marked with the VALID check box.
So I discovered that indeed I had an empty region inide the template
