Hi, there are several unanswered posts on the forums about how to replace media using the API using Python. I struggled with this myself, and so I’m posting my working solution.
import os
import requests
from requests_toolbelt.multipart.encoder import MultipartEncoder
def update_media(media_name, filename):
"""replace a media by name with content from a local file"""
access_token = get_access_token()
headers={
"Authorization": f"Bearer {access_token}"
res = requests.get(f"{URL}/api/library", headers=headers, params={
"media": media_name
try:
media_id = [
d["mediaId"] for d in res.json()
if d["name"] == media_name
][0]
except IndexError:
print("no such media")
basename = os.path.basename(filename)
upload_filename = f"{int(time.time())}-{basename}"
mimetype = mimetypes.guess_type(basename)
encoder = MultipartEncoder({
"oldMediaId": str(media_id),
"name": basename,
"updateInLayouts": "1",
"deleteOldRevisions": "1",
'files': (upload_filename, open(filename, 'rb'), mimetype),
headers.update({"Content-Type": encoder.content_type})
res = requests.post(f"{URL}/api/library",
headers=headers,
data=encoder
new_media_id = res.json()["files"][0]["mediaId"]
print(f"replaced media {media_id} with {new_media_id}")
hope it helps someone!
