xibo-cms-3.1.2
Installation Method
Custom install
Operating System
Linux
Hi, I’m trying to install xibo, when I go to the third screen it gives me the following errors:
Slim Application Error
The application could not run because of the following error:
Details
Type: Error
Code: 0
Message: Class ‘Illuminate\Support\Collection’ not found
File: /www/enzo/xibo.mysite.com/vendor/xibosignage/support/src/Xibo/Support/Sanitizer/RespectSanitizer.php
Line: 40
Trace
#0 /www/enzo/xibo.mysite.com/lib/Helper/SanitizerService.php(26): Xibo\Support\Sanitizer\RespectSanitizer->setCollection(Array)
#1 /www/enzo/xibo.mysite.com/lib/Helper/Install.php(78): Xibo\Helper\SanitizerService->getSanitizer(Array)
#2 /www/enzo/xibo.mysite.com/lib/Helper/Install.php(107): Xibo\Helper\Install->getSanitizer(Array)
#3 /www/enzo/xibo.mysite.com/lib/routes-install.php(95): Xibo\Helper\Install->step3(Object(Slim\Http\ServerRequest), Object(Slim\Http\Response))
#4 [internal function]: {closure}(Object(Slim\Http\ServerRequest), Object(Slim\Http\Response), ‘3’)
#5 /www/enzo/xibo.mysite.com/vendor/php-di/invoker/src/Invoker.php(82): call_user_func_array(Object(Closure), Array)
#6 /www/enzo/xibo.mysite.com/vendor/php-di/slim-bridge/src/ControllerInvoker.php(47): Invoker\Invoker->call(Object(Closure), Array)
#7 /www/enzo/xibo.mysite.com/vendor/slim/slim/Slim/Routing/Route.php(384): DI\Bridge\Slim\ControllerInvoker->__invoke(Object(Closure), Object(Slim\Http\ServerRequest), Object(Slim\Http\Response), Array)
#8 /www/enzo/xibo.mysite.com/vendor/slim/slim/Slim/MiddlewareDispatcher.php(81): Slim\Routing\Route->handle(Object(Slim\Http\ServerRequest))
#9 /www/enzo/xibo.mysite.com/vendor/slim/slim/Slim/MiddlewareDispatcher.php(81): Slim\MiddlewareDispatcher->handle(Object(Slim\Http\ServerRequest))
#10 /www/enzo/xibo.mysite.com/vendor/slim/slim/Slim/Routing/Route.php(341): Slim\MiddlewareDispatcher->handle(Object(Slim\Http\ServerRequest))
#11 /www/enzo/xibo.mysite.com/vendor/slim/slim/Slim/Routing/RouteRunner.php(84): Slim\Routing\Route->run(Object(Slim\Http\ServerRequest))
#12 /www/enzo/xibo.mysite.com/vendor/slim/twig-view/src/TwigMiddleware.php(125): Slim\Routing\RouteRunner->handle(Object(Slim\Http\ServerRequest))
#13 /www/enzo/xibo.mysite.com/vendor/slim/slim/Slim/MiddlewareDispatcher.php(147): Slim\Views\TwigMiddleware->process(Object(Slim\Http\ServerRequest), Object(Slim\Routing\RouteRunner))
#14 /www/enzo/xibo.mysite.com/vendor/slim/slim/Slim/Middleware/RoutingMiddleware.php(59): class@anonymous->handle(Object(Slim\Http\ServerRequest))
#15 /www/enzo/xibo.mysite.com/vendor/slim/slim/Slim/MiddlewareDispatcher.php(147): Slim\Middleware\RoutingMiddleware->process(Object(Slim\Http\ServerRequest), Object(class@anonymous))
#16 /www/enzo/xibo.mysite.com/vendor/slim/slim/Slim/Middleware/ErrorMiddleware.php(107): class@anonymous->handle(Object(Slim\Http\ServerRequest))
#17 /www/enzo/xibo.mysite.com/vendor/slim/slim/Slim/MiddlewareDispatcher.php(147): Slim\Middleware\ErrorMiddleware->process(Object(Slim\Http\ServerRequest), Object(class@anonymous))
#18 /www/enzo/xibo.mysite.com/vendor/slim/slim/Slim/MiddlewareDispatcher.php(81): class@anonymous->handle(Object(Slim\Http\ServerRequest))
#19 /www/enzo/xibo.mysite.com/vendor/slim/slim/Slim/App.php(215): Slim\MiddlewareDispatcher->handle(Object(Slim\Http\ServerRequest))
#20 /www/enzo/xibo.mysite.com/vendor/slim/slim/Slim/App.php(199): Slim\App->handle(Object(Slim\Http\ServerRequest))
#21 /www/enzo/xibo.mysite.com/web/install/index.php(101): Slim\App->run()
#22 {main}
Go Back
Can anyone help me solve?
Thank you
