Ive got a really easy question to ask. How do I tell what the address is for my CMS?
Im using a Zotac ZBOX with XAMPP installed as the web server. I have gone through installing it and have access to the localhost/xibo/xibo-cms-1.7.3/ page. I am also using another Zotac ZBox as the Windows Player.
I am now trying to get one of players to communicate with the server and I have no idea what the address would be. I have changed the key to something I would know, but whenever I try to access it, it states that it is unable to connect to the remote server.
I have tried the following:
http://127.0.0.1/
http://127.0.0.1/xibo-server
on the server computer, start menu> cmd
At the console, type ipconfig and hit enter. That is the ip of your server.
It would be better to set up a manual ip windows as if DHCP when you reboot can change the IP.
Localhost is only accessible from the same machine.
Went through those steps, got the result of
Connection-specific DNS Suffix
Link-local IPv6 Address
IPv4 Address
Subnet Mask
Default Gateway
I used the IPv4 Address and got the result of:
Saving with CMS…Please wait… Invalid URI: The formate of the URI could not be determined.
I then added http:// to the front of it and and a / to the end and got:
Status
The request failed with HTTP status 404: Not Found.
Do I need to add a port or something to the end of the address?
@njohnson
Try using http://(IPv4 Address of CMS)/xibo/
Tried that, got the result of
Status
I used the IPv4 address from the ipconfig command with http:// and put /xibo/ at the end of it.
(http://ipv4address/xibo/ )
When I type that exact address into the web browser on the PC Im using as the server, it brings me to the Index of /xibo page.
Additionally, when I type it into the web browser on the PC Im using as a Player Client, it brings me to the same Index of /xibo page.
alex
May 27, 2015, 7:30pm
6
njohnson:
It’ll be http://ipv4address/xibo/xibo-cms-1.7.3
as that’s the URL you use to log in in your case
I think i am having the same issue.
My xibo is installed to the root of the htdocs in xampp so the address is:
http://localhost:8080/xibo/
When i use my computers ip: http://192.168.1.135/xibo i get a message saying, unable to connect to cms at that address,
Any ideas?
alex
June 1, 2015, 6:29am
8
You’re missing your custom port number.
The address would be
http://192.168.1.135:8080/xibo
