I’m trying to create a template based on a simple layout as an ADMIN. Then share it to a group of users. here is my steps:
• Create layout with 1 zone ( I added permissions to the region for user groups)
• Save a template based on this layout
• Add permissions to this template to a user group
• Disconnect as admin and then Connect as a user from that user group
• Create a new layout based on the template that this user group can access
• Try to add widgets to the template
• Get error for Access denied
I have made a short movie to show my exact path, you can check it here: https://www.loom.com/share/594f89f07a254c03a541a7d55aeddeff
