Once installed, the Xibo CMS comes with a number of options that can be configured from the Administration section of the CMS main menu: CMS Configuration
Further settings and options which you may find useful can be found using the following links:
Command Functionality
Date Format - PHP
Folders
Library Quota
Maintenance
Password Settings
Proof of Play Settings
Resolutions
Tags
Transitions
Using MongoDB to store time series data
